Old 09-08-2007, 12:26 AM   #1 (permalink)
Default Which Ethernet Card? D-Link or Intex?
Hello
I am new here. I have to buy a PCI ethernet card for Dataone broadband connection. Can anyone tell me which one of these two is better? The D-Link model Number is DFE-520TX I do not know about Intex card. I am running a Pentium 3 with 256 MB RAM. (Old Computer).
Are there some other affordable cards available? I want cheapest card (10/100Mbps) but it should be very stable.
Thank You.
powerdome is offline
Old 09-08-2007, 12:29 AM   #2 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: Which Ethernet Card? D-Link or Intex?
D-link r little costly ones... so go for tech-com.. its around 150
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 09-08-2007, 10:24 AM   #3 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Default Re: Which Ethernet Card? D-Link or Intex?
But D-Link are of better quality. Cheaper the worst.
navjotjsingh is offline
Old 09-08-2007, 11:39 AM   #4 (permalink)
go for d-link, it will give u better quality..
thadhanihemant is offline
Old 09-08-2007, 12:34 PM   #5 (permalink)
bajaj151's Avatar
I suggest you to go for D-LINK...
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now
Old 09-08-2007, 12:38 PM   #6 (permalink)
King of my own Castle
freshseasons's Avatar
Smile Re: Which Ethernet Card? D-Link or Intex?
If you have to buy the card one time go for Dlink.
Intex,Techcom,and other have inferior chipsets. Moreever they cannot handle the Higher FSB of PCI slot when you over clock the CPU and mother board.
Dlink just dishes in everything..
Go for the best , hardly a difference of 200bucks.
freshseasons is offline
Old 09-08-2007, 01:57 PM   #7 (permalink)
Deadman Walking
Batistabomb's Avatar
Absolutely D-Link
Batistabomb is offline
Old 09-08-2007, 02:01 PM   #8 (permalink)
Noobie Pro
alsiladka's Avatar
D-Link is a trusted brand, been using it from a long time.
www.twitter.com/alsiladka
alsiladka is offline
Old 09-08-2007, 03:19 PM   #9 (permalink)
Thank you to all forum members who have helped me. I am now going to get the D-Link card. The difference in price is not that much taking into account I intend to use this card in future for long time as well. I consider it a one time investment.
Thanks everyone.
Old 09-08-2007, 03:41 PM   #10 (permalink)
"The Gentleman"
vish786's Avatar
if u want a good quality card, then any time go for D-Link blindly if cash isnt a prob.
- Dijkstra
vish786 is offline
Old 09-08-2007, 05:03 PM   #11 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
bt whots the price ???
... W H O T ...
ax3 is offline
Old 09-08-2007, 06:41 PM   #12 (permalink)
@freshseasons
Overclocking a P3 with 256MB! ??????
V.Prem Kumar
janitha is offline
Old 09-08-2007, 08:00 PM   #13 (permalink)
slugger's Avatar
dey gotta price diff of around 340-350 bux
d-link ka costs around 490-500
generic ehternet cards cost around 150 bux,
have 1 on my comp [tho never use it, just 4 sum sw dat need it 2 b present 4 installation/usage], never troublebled me
slugger is offline
Old 09-08-2007, 08:22 PM   #14 (permalink)
I had used a cheap card (Rs.200 at that time)for few months when my Mobo didn't have built in Lan and it worked without any problem.
V.Prem Kumar
janitha is offline
need help configuring my intex capture card !!! hmvrulz Reviews 5 22-09-2008 05:18 PM
Intex Internal TV Card patkim Hardware Q&A 1 10-06-2007 02:52 AM
Any one of u use Intex LAN card with linux ?? eagle_y2j Open Source 5 01-01-2007 09:46 PM
intex ethernet card question rk Hardware Q&A 10 09-04-2006 03:16 AM
