Old 06-03-2005, 08:32 AM   #1 (permalink)
Default copy from acrobat file
I'm not able to copy and paste data from an acrobat file. Kindly tell me how to do this?
callsriram is offline
Old 06-03-2005, 08:39 AM   #2 (permalink)
tuXian's Avatar
The document has got the acrobat security enabled. So copy and paste might also be disabled. Check even printing is also not allowed sometimes.
I dont know any way except u know the pwd for changing the permissions and for that you should have adobe acrobat installed not the acrobat reader but the so called acrobat writer.
tuXian is offline
Old 06-03-2005, 01:18 PM   #3 (permalink)
vysakh's Avatar
take a screenshot and paste it in irfan view. select the required part and copy it. Now you can paste it wherever you want
Incompatible message format
vysakh is offline
Old 06-03-2005, 02:08 PM   #4 (permalink)
enoonmai's Avatar
Even if you have Adobe Acrobat Professional installed, you will still be prompted for a master password which would have been supplied when the document was created. Modifying a document without the author's permission is illegal and the protection exists for a reason. You have tools that can decrypt and save the file without the password restriction, but thats illegal and won't be discussed here.
Playing FEAR XP/LSW2
enoonmai is offline
