Old 07-08-2007, 08:45 PM   #1 (permalink)
hansraj's Avatar
Default one more bsod prob fnds.... need help
just now bought a new lenovo 5000 y300 laptop thinking that life is going to be better but this bsod prob has restricted my use of pendrive or for that matter even the loading of drive from true crypt application. the error message does not last enough to read whats the problem and the minidump file is unable to tell me which driver is faulty. however the event viewer is able to give this info which iam pasting. Can anyone help me as i have given up from my side.
The computer has rebooted from a bugcheck. The bugcheck was: 0x1000000a (0x000000b0, 0x00000002, 0x00000000, 0x804ef13c). A dump was saved in: D:\WINDOWS\Minidump\Mini080707-01.dmp.
hansraj is offline
Old 07-08-2007, 09:54 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
Default Re: one more bsod prob fnds.... need help
Disable the auto pc restart option as follows : rt click mycomp>proprerties>advanced>startup&systemrecovery >settings>unclick
automatically restart. knowing the error code, can help identify the problem/solution.
see here then The "Blue Screen Of Death".
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 08-08-2007, 03:06 PM   #3 (permalink)
hansraj's Avatar
i think that this is definitely happening due to some conflicting device driver.... and i have checked it that this is not happening when i connect the pendrive in safe mode so its most probably a third party driver. now i need a application which can give me the option of disabling the loading of drivers of my choice to get on to the conflicting one.
i think my brain is in the rt direction. friends any good software in u r mind for loading/unloading the various drivers in my pc??
hansraj is offline
PC down after BSOD satyamy Hardware Q&A 11 28-04-2007 12:20 AM
Got BSOD int86 Hardware Q&A 6 25-10-2006 07:09 PM
Bsod.... SoulgrinD Software Q&A 1 03-07-2006 01:11 PM
BSOD..help.. zuala77 Software Q&A 1 19-01-2006 02:16 AM
BSOD digitizen Hardware Q&A 1 10-11-2005 09:59 PM
