hello frns recently i fromatted windows n created a new partition of 5 gb out of 25 gb allotted to it earlier...nw d problem is that this partition(5gb) is created as primary partition....i want to join this with another 5 gb of partiton which is extended partition...how can i do this???
You can use Partition Magic. However; like shantanu I would suggest u to start a fresh.
So delete the 5 gb partition as well as 20GB partition and then create a 20gb partition. This will become ur primary partition and 5gb would become extended.
I guess u don't have any data in it as of now
Agreed! I have used partition magic many times and never once had lost data...
“They put me here because I’m from Canada and they think I’m slow, eh?..."
@sharma
d00d if u got no data on d HDD den cre8 new partitions deleting all older 1s
ID ur HDD and use ur HDDs Disk wizard 2 do so
u may use sumthin like UBCD 2 do so
If you are not having enough time to type full words and using shortcuts which are not understandable by a beginner then why are you there? Go and first complete your work!!!!!!!!!
