Old 17-08-2004, 02:28 AM   #1 (permalink)
Default xmnt2002 file missing!!!
Hello guys n gals, if any. I am facing a strange problem while starting my Win XP Pro. While starting, it shows a message "xmnt2002 file missing. Skipping autocheck..." at a blue screen just before the Welcome screen.
This problem occured after I accessed my friends Hard Disk connecting it as the primary slave which had crashed.
I manually found the file to be from the Partition Magic program installed on my friends hard disk.
How should I remove that message from my system?
Moin is offline
Old 18-08-2004, 01:10 AM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
You should remove the entry from
Start > Run > Msconfig (press enter)
Click on Startup tab , Find and disable the offending entry ..
Click Apply and reboot ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
- by Piyush
