Old 05-08-2007, 09:42 PM   #1 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
Default Hide my folder ...
Hi all
i just want to hide my files and folders...
can u suggest a software..
i use hidefolders
but the problem is when hard disk to hard disk is copied... hide folders doesnt hide my folders..
can anyone suggest a software which is reliable and doent eat up my memory
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
naveen_reloaded is offline
Old 05-08-2007, 09:43 PM   #2 (permalink)
slugger's Avatar
Default Re: Hide my folder ...
convert ur partition 2 ntfs and encrypt ur files, shud work even if taken to a diff comp
slugger is offline
Old 05-08-2007, 09:53 PM   #3 (permalink)
i dont get u ..
can u explain././
Know My Thoughts..
Old 05-08-2007, 10:15 PM   #4 (permalink)
God of Mistakes...
Garbage's Avatar
Wink Re: Hide my folder ...
Originally Posted by naveen_reloaded
Hi all
i use hidefolders
Just check HIDDEN from folder properties....
Just kidding dude...
The better way is to Encrypt rather than hidden.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 05-08-2007, 10:16 PM   #5 (permalink)
slugger's Avatar
convert d partition u want 2 secure d data on in2 NTFS
den go 2 d drive, right click on d drive letter, select Properties
den select d General tab in d window dat opens up
click on a Advanced button. Another win will open up
in dat there will b an option dat says Encrypt data to secure data, check it and den all ur dat wud become encrypted [meaning safe, well almost safe at least]
slugger is offline
Old 05-08-2007, 10:46 PM   #6 (permalink)
well can i convert just klike that or shall i need to do any prior backups things liket h\\that...
Know My Thoughts..
Old 05-08-2007, 10:51 PM   #7 (permalink)
slugger's Avatar
converting it from non-ntfs 2 ntfs will not require n e back up ,as data will not de deleated
just use d command prompt
slugger is offline
Old 05-08-2007, 11:09 PM   #8 (permalink)
sorry to ask so many question but right now i am running azureus and i am storing thise files there onle(d:/) so will it affect it ..and how long wilkl it take???
Know My Thoughts..
Old 05-08-2007, 11:16 PM   #9 (permalink)
slugger's Avatar
just convertin it to ntfs will actually imporve file transfer speeds
but encryptin it will mena dat every time u access d data it wud first have 2 b decrypted b4 runnin, so a lil'l drop in speed is normal
BTW
i suggest u shtdown AZeurus or any program accessing d drive b4 startin d conversion process
actually since u have a half d/ld file in dat drive, not sure if d file will b affected or not
but ne subsequent adition shud not b affected [AFAIK]
slugger is offline
Old 05-08-2007, 11:27 PM   #10 (permalink)
thnks slugger..
is there anyother software which we can rely on for this prurpose of hididng???
Know My Thoughts..
Old 05-08-2007, 11:35 PM   #11 (permalink)
slugger's Avatar
hiding w/o encryption is useless, u may wan 2 try
T r u e C r y p t
FEATURES
* Creates a virtual encrypted disk within a file and mounts it as a real disk.
* Encrypts an entire hard disk partition or a storage device such as USB flash drive.
* Encryption is automatic, real-time (on-the-fly) and transparent.
* Provides two levels of plausible deniability, in case an adversary forces you to reveal the password:
1) Hidden volume (steganography – more information may be found here).
2) No TrueCrypt volume can be identified (volumes cannot be distinguished from random data).
* Encryption algorithms: AES-256, Serpent, and Twofish. Mode of operation: LRW.
slugger is offline
Old 05-08-2007, 11:44 PM   #12 (permalink)
The Frozen Nova
casanova's Avatar
Few questions about encryption.
I have two OS XP and Vista and I encrypt a folder say mistress from XP.
Can some other user from XP or vista access it and what if I format my system drive and reinstall my os as a fresh.
www.nerdweed.blogspot.com
casanova is offline
Old 05-08-2007, 11:49 PM   #13 (permalink)
slugger's Avatar
u need d same sw 2 decrypt it and also n e authorisation dat u may have put while encrypting it
slugger is offline
Old 05-08-2007, 11:57 PM   #14 (permalink)
The Frozen Nova
casanova's Avatar
If I encrypt with the default windows encryption available.
casanova is offline
Old 06-08-2007, 12:01 AM   #15 (permalink)
slugger's Avatar
d NTFS-walla encryption?
i think u will need sum sort of authorisation 2 decrypt it 2
[dun remember xactly, cause i dont use d featur now and had tried loong time back, everyhtin on my rig is open 2 scrutiny ]
y don't u try it out and keep us posted
wud b intrested in refreshing my memory
slugger is offline
Old 06-08-2007, 12:21 AM   #16 (permalink)
The Frozen Nova
casanova's Avatar
Thx for the info. Will make something dummy and update it soon.
casanova is offline
How to hide folder Kaushal Hiwarkar Software Q&A 4 13-07-2007 05:45 PM
Hide Files/folder Without Any Software saurabh kakkar Tutorials 12 21-04-2007 08:35 AM
hide contents of this folder iMav QnA (read only) 6 03-01-2007 04:59 PM
How to hide folder in windows XP without using folder guard sridatta Software Q&A 23 06-12-2006 06:32 AM
How to Remove Hide Option Frm Folder Option Chindi_Chor QnA (read only) 17 23-03-2006 11:18 PM
- by Piyush
