03-08-2007, 10:08 PM
All Transcend/Kingston pendrives not detected..help??
I have P-4 1.6 GHz old machine which has usb 1 onboard .so i have installed usb 2.0 pci card .. but some of the drives are not recognised by usb 2.0 ..and only some like iball etc are detected by usb 2.0 .//
where as all the pen drives are accepted by usb 1
how to solve this problem...
03-08-2007, 11:09 PM
"The Gentleman"
Re: All Transcend/Kingston pendrives not detected..help??
download the kingston flash / pen drive drivers.. may be then they will work fine.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
04-08-2007, 02:19 PM
also my sony cybershot digital cam is not detected..what do i do??
04-08-2007, 02:23 PM
"The Gentleman"
as i said earlier search for the drivers for the same.... if u find it, its well and good. otherwise its time to upgrade ur system.
- Dijkstra
04-08-2007, 02:43 PM
Hope you have the appropriate service packs installed.
04-08-2007, 03:44 PM
"The Gentleman"
Originally Posted by slugger
n e way d flash drive drivers dat vish is tkin abt is only 4 98 and ME
just updating the usb drivers for win xp wont help... coz its usb 1.1 version... so sometimes it is necessary for installing specific drivers also.... mobo has conflicts while using the 2.0 and 1.1 pen drive and hdd.
and yes those driver r mostly for 98 and me .
- Dijkstra
04-08-2007, 04:10 PM
d onboard usb is 1.1 but d card usb is 2.x so dint i ask him 2 install d USB 2.0 drivers
Mostly!!!! show me 1 flash drive mfg which has provided d drivers 4 WinXP/2000/2003
and it was extremely irresponsible of u 2 ask him 2 upgrade his computer just for this
Reason: Automerged Doublepost
04-08-2007, 04:24 PM
Install some software like Google Picasa and then plug in your camera. See if the software detects that you have plugged in a camera?
"The Gentleman"
oh i forgot that he's usin pci usb... completely forgot abt that in that post.
there r none drivers for flash drives to make them run in winxp. but since its was usb 1.1 version, i just told him to give a try.... is that costin him ?? no ... so what wrong in givin a try. and look this is what i said in my first post. " download the kingston flash / pen drive drivers.. may be then they will work fine. "
since its a pretty old system as it has usb 1.1... anyone can guess its a old system and i'm not telling him to go now to shop and buy the system right now bear that in mind... their is nothing wrong in giving opinion / suggestion... its up to him to buy it.
- Dijkstra
04-08-2007, 06:33 PM
I often use a PII 266 MHz with 128 MB RAM and 4.3 GB HDD comp to surf
old-new does not matter wat matters is if ur config is doing its job perfectly 4 u or not
d rig has got a 1.6 GHz processor d00d. Toy StoryI was rendered on a pltaform similar to this [i think]
so do u NOW realise d true power of d processor
04-08-2007, 06:46 PM
"The Gentleman"
 ... i'm still usin 386 and 486 system for tally in ma office.  < not lieing >
- Dijkstra
05-08-2007, 12:31 PM
dudes dudes dudes ........ i have WIN XP SP-2 with all the latest windows updates ..the pci card is well plugged in and installed in win xp ..in device manager it shows properly installed .. also some usb devices are recognised by it n accessed properly ........... but for some devices it dont works ..its a unique problem i m facing ..now try to tell the solution...
@ slugger
what do u mean by " MANDREL de India!!!!!"
05-08-2007, 12:35 PM
did u install d SP after attachin d PCI USB card or b4, if it was installedb4 attachin d card, den probably d usb2.0 drivers wud not hav been installed bcos der ver no usb 2.0 slot
also did u try attachin d non-detectin USB driv on d mobo's USB 1.x slot and c if it getting detected [but with d slow speed message]
EDIT
Originally Posted by NagpurDaMunda
@ slugger
ENCRYPTED JOKE. A hint:Its got 2 do sumthin wit a certain branch of Engg
05-08-2007, 02:47 PM
EDIT
3] When ll u decrypt that joke?
2]i tried "attachin d non-detectin USB driv on d mobo's USB 1.x slot and c if it getting detected [but with d slow speed message]" ..it is working fine..
1] I installed after card was attached...so no issues..
05-08-2007, 02:58 PM
f the JetFlash drive worked on another platforms, but not on yours, then the problem probably lies within your system.
Below are some recommendations what should help you to solve this problem:
(1). If you had previously installed USB drivers for other devices, please remove them first. Enter computer`s safe mode and remove all unknown devices from "Device Manager -> Universal Serial Bus Controllers”, then restart your computer in normal mode and then reconnect the JetFlash drive.
(2). Enter BIOS setting and follow these procedures -> Load Optimized Defaults [Y] -> Integrated Peripherals -> USB Legacy support [Enable] -> Save & Exit Setup [Y] (Please refer to your computer`s Motherboard`s manual for more information).
(3). Reinstall your computer`s motherboard USB drivers.
(4). Update the BIOS for your motherboard.
SOURCE
as iBALL working properly [those small black chewing gum thingy u talkin abt na!!], it is probably bcos i think they r not really a Flash drive, per se, but memory cards with a usb interface
2 check my hypotheisis,try 2 lay ur hand on a card reader and a card and c if it gets detected normally by d pci usb hub
As 4 decrypting it [my signature], if u intrested u got 2 find it out urself
05-08-2007, 07:38 PM
Try the card in someone else's pc(with usb1.x) and if it doesn't work try and get a replacement.
06-08-2007, 01:26 PM
Cool as a CUCUMBAR ! ! !
uninstall old drivers .... restart ..... install NEW drivers 4 usb 2.0 ........
hope it solves ur problem .......
... W H O T ...
08-08-2007, 11:57 PM
#19 (permalink)
done this ..but still its not working
Search this Thread |
