Old 05-03-2005, 02:12 PM   #1 (permalink)
Default Changing the order in right click menu ??
Hi guys,
In "my computer", we all use double click on a hard drive icon to see the content of that Hard disk drive[ C, or D...], i started using Window blinds...and then after sometime..when i double clicked,.... the windows search program started popping up instead of the drive getting opened up.
And then i found that when i right clicked the drive icon...i was able to see the "open" caption in the 2nd place in the right click menu and the "Search" text in the 1st place of the menu.....
So everytime i double click the hard drive icon the windows search open up.
Guys can anyone help me resolve this problem ??
[lokesh] is offline
Old 05-03-2005, 03:47 PM   #2 (permalink)
enoonmai's Avatar
Open Windows Explorer, go to Tools>Folder Options>File Types. When the list loads look for
Extension     File Type
(NONE)        Drive
(NONE)        File Folder
(NONE)        Folder
and then select them and click Advanced. If you already have open or explore, in that list, select it and press the "Set Default" button. If you don't click the " New" button, and enter open or explore in it and set the program to explorer.exe. Set this as the new default and you should be back to normal.
Playing FEAR XP/LSW2
enoonmai is offline
Old 05-03-2005, 04:00 PM   #3 (permalink)
yes! do as directed .. by enoonmai ... it shd work out ...
But i just wanted to inquire tht how the right-click menu is expanded using some players like JetAudio ...
actually i want registry changes ... can neone help me in this ?
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 05-03-2005, 04:07 PM   #4 (permalink)
enoonmai's Avatar
When you install third party programs, they add their entries to the HKEY_CLASSES_ROOT/Folder/shellex key. These are system wide explorer changes. Customized context-sensitive right click options can be found under
HKEY_CLASSES_ROOT/Folder/shellex/ContextMenuHandlers
or
HKEY_CLASSES_ROOT/*/shellex/ContextMenuHandlers
You can delete orphaned or unused handlers from here.
Be careful as you would need to know which it is that you are deleting and also you need to look up CLSIDs to be sure if it lists a CLSID instead of a program detail, as it usually does.
enoonmai is offline
Old 05-03-2005, 04:09 PM   #5 (permalink)
Thanks! Krishnan ... yeah! i'll take care of wat am i deleting ... thanks! again ...
Old 05-03-2005, 09:25 PM   #6 (permalink)
Thanks...but a new problem, when i double click...a new window gets opened up...i checked the folder options-->general tab, it is specified as open folder in the same window only....but still it opens up in new window...i think along with explorer.exe something else should also be added, like some -s or -r...i am not sure ???
Known is a Drop, Unknown is an Ocean...
[lokesh] is offline
Old 06-03-2005, 02:01 AM   #7 (permalink)
enoonmai's Avatar
No, that's how it works. To remove this problem and restore it to its previous setting, go to Tools>Folder Options>File Types and select (NONE) Drive again and select the Open action that you added and click the Remove button. This will remove all defaults and revert the action to the system default, opening the drive contents in the same window. If the option to remove is grayed out, then click Start>Run and type in
regedit
and press Enter. In the Registry Editor window that opens up, navigate to
HKEY_CLASSES_ROOT/Drive/shellex
Click the plus sign next to the shellex key to drop the list down, and right click the "open" key and delete the key. Close regedit and check. It should be working as usual now.
enoonmai is offline
Old 06-03-2005, 02:20 PM   #8 (permalink)
Thanks...it worked...except that it is HKEY_CLASSES_ROOT/Drive/shell instead of shellex.
Thanks a lot!
[lokesh] is offline
Old 06-03-2005, 02:22 PM   #9 (permalink)
enoonmai's Avatar
You're right, my mistake. Sorry for typing shellex by force of habit.
enoonmai is offline
Old 06-03-2005, 02:27 PM   #10 (permalink)
It's ok....it happens sometimes....
[lokesh] is offline
- by Piyush
