Deep sorry to disturb again.
Is the procedure same for adding/editing other recpords like CNAME, PTR etc.
My domain is presently with net4domains but I am shifting my registrar and now going to be with Directi who provide a service called Managed DNS which enables a domain owner to edit the CNAME and SOA records apart from the regular MX,NS,A.
So another question is that if I am with Directi then will CNAME and SOA changes should be done from Directi control panel or do I need to again contact the webhost server admin.? Which record holds good the one from Domain registrar or with the Host.??
I also invite your attention to my last post in IP address related thred
http://www.thinkdigit.com/forum/viewtopic.php?t=15687
Would be glad if you could briefly answer it in easy terms for me
