Old 31-07-2007, 10:03 PM   #1 (permalink)
bajaj151's Avatar
Default Strange Temperature Display ???
I am using Zebronics Antibiotic Cabinet from last 3-4 months.
Nowdays, the cabinet is showing strange TEMPERTAURE DISPLAY.
Instead of temperature, it showing "H1"....I dont know, what my cabinet trying to show in H1 ??????
Plz solve this STRANGE problem...
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now
Old 03-08-2007, 10:44 AM   #2 (permalink)
bajaj151's Avatar
Default Re: Strange Temperature Display ???
Old 03-08-2007, 02:08 PM   #3 (permalink)
slugger's Avatar
wat did u do b4 u started seeing d H1 display?
did u check if the connection 2 d temp sensors r proper?
r u getting d proper temp readings from d BIOS? if yes den der cud b sum problem with d ur LCD display
if u got sum warranty and it is still under warranty u might want 2 take it back and ask wats going wrong
slugger is offline
Old 03-08-2007, 06:52 PM   #4 (permalink)
bajaj151's Avatar
Well I dont think there is any warranty for cabinet..If yes...plz lemme know...
ya...for smps..its 1 yr....
Old 03-08-2007, 07:17 PM   #5 (permalink)
slugger's Avatar
no usually cabinets dont come with any knid of warranty
but ne way u shud know better cause you bought it
wat abt d other things i askedu 2 check out??
slugger is offline
Old 03-08-2007, 11:46 PM   #6 (permalink)
bajaj151's Avatar
ya....connections are properly attached and bios also showing the temperature
Now...what should I do ?
Old 04-08-2007, 12:01 AM   #7 (permalink)
Rebooting
Choto Cheeta's Avatar
Here hear for some Temp Checking tools
Please List Basic C2D / Dual Core Overclocking Tips
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 04-08-2007, 12:32 AM   #8 (permalink)
slugger's Avatar
arre mere mele mein bichde huen bhai!!!
probblem is not with temperature, d BIOS is showing correct temp, but d same temp is not being dispalyed on d LCD display of his cabinet.
i bet da if he installs a temp display sw in his OS it 2 will display d correct temp.
d problem is wit d lcd display
slugger is offline
Old 11-08-2007, 11:24 PM   #9 (permalink)
bajaj151's Avatar
where is temperature sensor located in my cabinet.....so that i should check that before proceding in any other conclusion......
Old 15-08-2007, 01:44 PM   #10 (permalink)
bajaj151's Avatar
Old 15-08-2007, 02:19 PM   #11 (permalink)
slugger's Avatar
y dont u try tracin d wire backe from d lcd dispaly and c where it leads back 2,
1 will surely lead back 2 d sensor
slugger is offline
Old 15-08-2007, 02:20 PM   #12 (permalink)
a_g = JPKN
s18000rpm's Avatar
other than temp. is other display (HDD, FAN, time...) working fine???
contact the Dealer & get the LCD replaced.
the white Wire with a small bulb at the end is the temp. sensor.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 15-08-2007, 08:52 PM   #13 (permalink)
bajaj151's Avatar
@s18000rpm
I think....dat small bulb u talking about is not there....
what should I do now......any alternative ??
Old 15-08-2007, 09:34 PM   #14 (permalink)
a_g = JPKN
s18000rpm's Avatar
this is that bulb thing.
check whether its there.
Old 15-08-2007, 09:35 PM   #15 (permalink)
bajaj151's Avatar
Noo..its not dere ....
wht shud i do now...
Old 15-08-2007, 09:39 PM   #16 (permalink)
a_g = JPKN
s18000rpm's Avatar
the LCD unit is removable.
if you can remove it, then take it to the dealer, he'll replace either the whole unit or that Temperature Sensor.
if you cant remove, the take the whole cabinet to the dealer.
Old 15-08-2007, 09:42 PM   #17 (permalink)
bajaj151's Avatar
Is dere any other alternative ?
Old 15-08-2007, 10:08 PM   #18 (permalink)
dOm1naTOr's Avatar
@bajaj151
me too have antibiotic.
My LED fan was gone after 1 month and 1 got the whole cab replaced. The warranty is for the whole cab and PSU carries seperate 1yr warranty.
So ull have to take the cabby to the retailer.
By the by, do anyone has problem with the backlight of the LCD?
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 15-08-2007, 10:16 PM   #19 (permalink)
a_g = JPKN
s18000rpm's Avatar
not yet
Old 15-08-2007, 10:39 PM   #20 (permalink)
bajaj151's Avatar
@ aravind_n20
U mean....dere is 1 yr warranty for cabinet also....
Old 15-08-2007, 10:44 PM   #21 (permalink)
dOm1naTOr's Avatar
ya...and one of my friend also replaced it as the backlight went completely out of order.
SO u just get it to the retailer.
My LCD backlight has also started blinkin sometimes. But u dun want to get it replaced as it wud take at least 2 weeks for it . I will better attach some LEDs inside that muself rather than to wait for 2 weeks.
G3: XPS M1530 |
FZ 16.
Old 15-08-2007, 10:56 PM   #22 (permalink)
bajaj151's Avatar
I think...i should go to nehru place and ask retailer to change my LCD unit or whole cabinet and 1 fan too....(1 led light missing)
First ...I call retailer to confirm...whether warranty comes only for PSU or whole cabinet
Old 15-08-2007, 11:40 PM   #23 (permalink)
dOm1naTOr's Avatar
the rear LED fan wud glow only if the sensor reports the temps above the one we set in the LCD panel. Thats why one is not workin. U can connect the fan plug into mobo pin. Itll just bent ellasticall a lil bit, but itll owrk just fine and works continuosly and dun depend on sensor temps nymore.
G3: XPS M1530 |
FZ 16.
Old 15-08-2007, 11:49 PM   #24 (permalink)
slugger's Avatar
oye!!! if u give him a call and ask him if it is covered under warranty, he may say no [y do xtra work]
take my advice, take ur cabinet 2 dat dealer and demand dat he replace/fix ur problem
show sum guts man in india no work gets done over d phone
sab kaam gardan pakadke usko marodke karvana padta hain
slugger is offline
Old 16-08-2007, 12:02 AM   #25 (permalink)
dOm1naTOr's Avatar
lol
G3: XPS M1530 |
FZ 16.
Old 16-08-2007, 01:06 AM   #26 (permalink)
yes the cabi too has 1 yr warranty
ranjan2001 is offline
Old 17-08-2007, 12:20 AM   #27 (permalink)
bajaj151's Avatar
thnx...
Old 17-08-2007, 12:22 AM   #28 (permalink)
a_g = JPKN
s18000rpm's Avatar
^problem solved?
Old 17-08-2007, 12:23 AM   #29 (permalink)
bajaj151's Avatar
No...will go to Nehru place tomm or day after tomm.....
will surely post...d result...hope for d best...
Old 24-09-2007, 12:53 PM   #30 (permalink)
bajaj151's Avatar
Well...thanks for all your support..
Finally...I replaced my LED panel...and bought new...which is working fine and solve my temperature problem.
And one more thing came to know from dealer that zebronics provides 3 yr warranty on SMPS.....and NO WARRANTY on cabinets.....
Is this temperature OK? phreak0ut Hardware Q&A 11 25-03-2007 02:31 PM
Strange Problem of display card System Of A Down Hardware Q&A 1 22-06-2006 04:51 PM
temperature chirayu garg QnA (read only) 2 07-06-2005 02:02 PM
CPU temperature sohin CPU / Motherboards 6 11-10-2004 11:17 AM
Temperature Avtar9 QnA (read only) 5 13-09-2004 12:50 AM
- by Piyush
