All the application shortcut's on my desktop are now open VLC media player...DOnt know exactly but somehow .ink is associate with VLC.I can open applications by browsing C:\Program Files\
Even i cant create any new shortcut....VLC open
Help me guys to restore it to default.....
" 99% computer Problems are between the PC & the CHAIR "
or u accidently changed the file association to open all files with VLC (folder options, file type) there should be a set default or something simillar, and if you search the forums there's probably a registry entry if u like to play with that as well.
“They put me here because I’m from Canada and they think I’m slow, eh?..."
