Old 30-07-2007, 04:18 PM   #1 (permalink)
lionheart133's Avatar
Default XML help
hi,
small help needed,
i am coding using XML,
i typed data in notepad and saved it as "disease.xml"
but after saving,i open the file,it opens in notepad instead of in the browser.
anyone out thr who could help
lionheart133 is offline
Old 30-07-2007, 06:13 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: XML help
right click the file>> properties >> open with>> ur browser..
Pathik is offline
Old 31-07-2007, 01:53 AM   #3 (permalink)
slugger's Avatar
u sure u put d quotes?
if u do den u cud just re-associ8 d file 2 open wit d prograaaam of ur choice
just selct d file by clickin on it, den right click on it 2 open d context menu
der u will find option Open with, select dat, a window wil open listin all d programs currently instlled, select d 1 u want it 2 open with and also check d box 2 d left of always use d selected program 2 open dis kind of file statement
den next time u wan2 mod it, just right click on d file again go2 open with...
it will also list notepad [all programs dat was used 2 open it], select it an it will open in notepad
slugger is offline
Old 31-07-2007, 09:51 AM   #4 (permalink)
Indian by heart
planetcall's Avatar
WTF.....lol how come you are into coding when you don't know these simple stuffs ? It doesn't matter what is associated to open your XML file. All that matters is that you can open it in an editor and edit it. You can see the tree structure in internet explorer
प्रासादशिखरेऽपि सन्न काको गरुडायते ॥
No matter how high a fool may rise, he remains a fool -RigVeda
planetcall is offline
Old 31-07-2007, 10:04 AM   #5 (permalink)
slugger's Avatar
d00d whose post r u responding 2?
slugger is offline
Old 31-07-2007, 09:14 PM   #6 (permalink)
Indian by heart
planetcall's Avatar
first post by lionheart.
- by Piyush
