View Poll Results: How much u download per week by P2P softwwares?
1 to 1.5 GB 6 46.15%
300 to 700 MB 4 30.77%
100 to 300 MB 3 23.08%
Voters: 13. You may not vote on this poll
Old 04-03-2005, 02:00 AM   #1 (permalink)
parthbarot's Avatar
Default How to get 8 to 15 Kbps speed in P2P softs?can any one tell?
can any one tell anything which can improve speed for p2p softs on dialup network?
dont tell that take broadband or grter capacity line...
plz if anyone nos abt that how to get more speed like 8 to 10 or more kbps in any p2p soft...
plz telll
regards....
www.techlads.com
Paarth.
parthbarot is offline
Old 04-03-2005, 02:22 AM   #2 (permalink)
dude seriously
how do u expect to get those speeds without ur net supporting it ?
what the speed of ur net ?
if u have say even 65 kbps u cant expect anything over 8kBps ... honestly think before u ask
No Mercy, No Limits.
theraven is offline
Old 04-03-2005, 12:53 PM   #3 (permalink)
LOL...this is like asking how can I get a 40 space from a 20 GB hdd or something..
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 04-03-2005, 01:39 PM   #4 (permalink)
vysakh's Avatar
well if i had a good 256kbps connection instead of this crappy dialup i would certainly have done that
Incompatible message format
vysakh is offline
Old 04-03-2005, 01:51 PM   #5 (permalink)
Maverick340's Avatar
Use BearShare.....itll give u the best speeds on a dial up....But certanly not 15 kbps(cough!)(cough!)
You and Me forever be ...
PSpwned
Maverick340 is offline
Old 04-03-2005, 02:24 PM   #6 (permalink)
Ethan_Hunt's Avatar
Well there's a limit for the transfer of file speeds on a Dial up connection.....even if u get the max sources in P2P clients like Kazaa then too u'll end up max on 3-4 Kbps download speeds.....Btw i myself am at total waste on 64k leased Line with max speeds of 9Kbps....atleast thats the fastest i have ever seen on my line.....so ya see no point in use of any software,advice,banging ur Modem,or at the most Choking ur Pc....it wont deliver that much speeds cause thats the way Dial up goes down
ohhh...yea one more query goes to u....i at first didnt notice the Poll on top and so out of total curiosity why the poll and a separate "non-realted-poll" question
V for Vendetta
Ethan_Hunt is offline
Old 04-03-2005, 05:12 PM   #7 (permalink)
swatkat's Avatar
remember that Net speeds r stated in Kilo bits per second and most browsers/downloaders/P2Ps show speed in Kilo Bytes per second....
and 1 Byte = 8 bits.........
now...do u want 8kbps or 8kBps ????????
http://swatrant.blogspot.com/
swatkat is offline
Old 04-03-2005, 05:48 PM   #8 (permalink)
i guess he means 8kBps..right?
PSpwned
Old 04-03-2005, 06:14 PM   #9 (permalink)
This is from wiki. I dont have the like so i'm posting the contents.
The best idea to get maximum is to download the one having more source. I found this one from wiki very intresting. Hope it help you
Introduction and Overview
The most frequent question regarding Shareaza or any other P2P Clients is about downloading. Everyone always believes they have to unlock some hidden feature to make their downloads fast. The reality? No option like that exists!
The truth is that downloading is subjective. You can only download as fast as other users can upload to you. If you try to download a file, and it only has a few users (sources), chances are it won't be too fast. Therefore, The more sources a file has, theoretically the faster it will be.
Note: Don't let the units fool you; there's a difference between 1 Kb ( kilobits ) and 1 KB? ( kilobytes )
1 Kilobyte = 8 Kilobits
Users often think that downloading at 16 Kb/s is fast and expect their downloads to finish quickly when in fact they're downloading at a slow 2 KB/s. To change the way Shareaza represents speed go to:
Shareaza Settings > General > Show rates in
and select the units most suitable for you. Click here to read more about Shareaza's Settings.http://wiki.shareaza.com/static/Options.General
Search the network for something really popular, some small file that has at least 50-100 sources - a popular song for example. Download it, and if it doesn't download at all or is going very slowly, then you may have a problem. An example would be to download Shareaza itself - using the "Magnet Link". That is the most popular file shared among Shareaza Users - so therefore the speed should be high. By following the instructions below, you can help fix this. However, if you’re downloading a rare file (low sourced) and the speeds arn't up to par, that's not Shareaza's fault.
Well, some of you probably stop here, claiming that your download has tons of sources, but isn't going anywhere. This is probably the fault of the eDonkey2000 network, a network designed for large files and consistant transfer rates. However, this logic doesn't always mean speed. If the same amount of sources were available on Gnutella2, the download would be screaming. Gnutella2 is much more efficient than eDonkey2000, so the more sources on Gnutella2, the better.
Now, you make ask... what about Kazaa? Kazaa has millions of users. Shareaza's main network (Gnutella2) only has around 60 thousand. This user difference shows how efficient Gnutella2 really is; with under 2% of the users that Kazaa has, it still holds it own. Keep promoting Shareaza and Gnutella2, and someday, the speeds on G2 will blow Kazaa out of the water.
Some files that you can download with Shareaza, however, can easily blow Kazaa away when Shareaza is used and configured correctly. This guide will help you find the right files and configure Shareaza correctly, so the download speed will give all of the P2P clients a run for its money.
What to Expect
From Gnutella2: Gnutella2 (G2) is Shareaza's premier network. The network is small compared to larger networks like FastTrack (Kazaa) or eDonkey, but it is powerful, with many features and great efficiency. You should expect smaller queues on Shareaza (1-25 is the norm) and "okay" speeds. For music, it is excellent, but offers only average speeds on larger files. The only thing hurting speeds on the big files is the low number of users. Hopefully, though, the network will grow and, in turn, so will the speeds. With the network growing every day, the speeds grow too.
Gnutella2 is optimal for both large and small files.
From Gnutella: A network of mostly small files, good for music. It is much like Gnutella2 in the way that it acts in a similar structure, but it lacks the efficiency and features. Even with more users than Gnutella2, it actually offers worse performance. It also has short queues, like Gnutella2.
Gnutella is best for smaller files (~ 4-10 MB).
From eDonkey2000: eDonkey is a network of long queues and large files. Don’t be surprised if you try to download something on eDonkey and you’re waiting in queues the size of your state's population. But, the network has pretty much everything, if you wait long enough (say, leave your download going overnight or longer). You'll be able to get most files eventually. Keyword: Eventually. The download is going to be slow, much slower than most other networks. This is why the network is suited for broadband users, who can leave their connections active all the time and wait through the queues and the slow download. However, there is a credit system involved - the more you upload to a user, the faster you go through their queues, helping you download faster. The longer you leave it on, the faster your download will be - to a point, of course.
eDonkey is best for larger files (20 MB +).
From BitTorrent: BitTorrent has a reverse strategy of many P2P networks. It is not searchable, but uses a website run 'Tracker'. This 'Tracker' indexes the users that has downloaded the file, and when you begin downloading it, you receive the source list. Because of this, you will have no trouble finding sources, but if the tracker goes down, then so does your download. BitTorrent has a strategy - "The faster you upload, the faster you download". The downloads, therefore, are very fast, since few can leech. However, people won't be downloading the file forever, so a download might last a week or so, but not much longer than that. There are no queues in BitTorrent, nor do you need to connect to anything other than the tracker when you are not downloading, much unlike Shareaza's other three P2P networks. Sites that have BitTorrent links are provided in the guide.
BitTorrent is optimal for both large and small files.
Use High Sourced/Verified Files
This part is so crucial, I decided it deserves its own section. This is, by far, the most important thing you can do to get good download speeds. Kazaa, because of the raw user count, has a lot of sources for about everything. Since Shareaza's supported networks are smaller, and there are a lot less sources for every file. However, there are plenty of sources for a few key files that exist on the network.
Since more sources usually results in more speed, then you have to find the high sourced files to get a good download rate. There are two ways to do this - finding them by searching, or using the recommended way - downloading off Indexing Sites (AKA Verifed Files or Release Sites)
Searching - When searching, sort by the number of sources. Then, look for the file you want from the top to bottom. That way, when see the file you want, you will get the one with the most sources. The more sources, the better chance of a fast download. Searching is only recommended if want single songs, or can't find what you need on release sites.
Release Sites - Certain popular sites provide links to files on Shareaza's networks that have been found by users and usually have to be of a certain standard. This means there are no bad quality or fake files around these sites, period. They also give you the added bonus to discuss the file and view lots more useful information about the download. Since this is a central source to hundreds of users, many people download these files, making them extremely high sourced. These sites are far superior to searching if you want Software, Movies, Games or Music Albums. For BitTorrent, this is literally the only way to use it.
Sites:
Recommended Sites for their respective network are underlined. It is best to try to find what you want on the underlined sites, but if you don't see it there, try the others. Be sure to refer to the above network introduction on which networks to use.
Gnutella2 Links (Optimal): PeerWeb or GamePhilez.
eDonkey Linksead-Donkey, FileNexus, Eselmetal, SharedFolder, AC3 Guru or ed2k-it.
BitTorrent: SuprNova, BtSites [Site List], Section31's Torrent Links [Site List], TorrentLinks.tk [Site List].
Setting Tips
These "option tweaks" should be the first you try to increase your download speed. They are quick, easy, and are often fix a configuration problem.
Update Shareaza
Shareaza is constantly updated with bug fixes, UI improvements, performance enhancements and new features. Find the latest release at the Shareaza Download Page.
Firewall and Router Configuration
If you have a firewall or router, be sure it is configured. You need to forward UDP and TCP packets through a port and configure Shareaza to use that port. See the Firewall/Router Configuration Page if you need help with this. This is a very important thing to do.
Modify the Download Connection Settings
Shareaza Settings > Internet > Downloads - Increase the number of 'Maximum Transfers' and 'Transfers Per file' to properly utilize your bandwidth - this allows you to optimize your "swarm" or "multisource" downloads. In other words - fixing this setting is strongly recommended
Shareaza Settings > Networks > eDonkey2000 - Increase the client link connections - this is the key to the eDonkey network, allowing you to stay in more queues and take advantage of your bandwidth.
Configuration Tips: Maximum Transfers - The ‘Maximum Transfers’ setting tells Shareaza how many transfers it can use to contact sources, and the more people it can contact, the faster it can start a download. The configuration of this setting depends on your bandwidth. Increase the setting until your bandwidth is allocated.
A good ballpark for this setting would be ⅔ if your download bandwidth (Example: 1000 kb/s Download Bandwidth = ~ 650 Connections). The absolute maximum to set this setting at is 1500 - unless you have a very high bandwidth connection (fewer than 1% of Shareaza users)
If you want to get the most out of your connection, try raising the number in increments of 50 -75 and seeing which gives you the best performance. It is BAD for the network to increase this setting too high, so be sure you don't set it to an unreasonable amount.
Windows 9x Users: Do not increase the Maximum Transfers too high or you could crash your system! See the The Lockups Page for more information.
Configuration Tips: Transfers Per File
The ‘Transfers per File’ is how many sources Shareaza can download from at once. The configuration of this setting also depends on your bandwidth. For a very high bandwidth connection, try 50. For a DSL connection of about 512 kb/s Download, try around 15. The more bandwidth you have, the more the setting should be increased.
Configuration Tips: Client Link Connections
This setting determines how many eDonkey sources it can stay it contact with, and the more people you can download from, the better. It is related more to your computer than bandwidth – if your computer is slower, than don’t push it too high. For a newer computer and pretty fast broadband, 800 – 1000 wouldn’t be out of the question.
Windows 9x Users: Do not increase the Client Link Connections too high or you could crash your system! See the The Lockups Page for more information.
Update your eDonkey Serverlist
Shareaza gets lists of eDonkey servers which it can search from a 'server.met', which is hosted by various websites. You can set Shareaza to automatically download these lists.
Click some of the links below to automatically add 'server.met's to Shareaza.
http://www.edonkey2000.com/
http://ed2kmet.x24hr.com/
http://www.charles-web.com/
http://www.de-site.de/
http://ocbmaurice.dyndns.org/
For More Information and locations, see bluetack's server.met page
Connect to Additional Networks
Shareaza Settings > Networks > Gnutella - Check “Connect to Gnutella2 today’. Check “Connect to Gnutella Today/Always, if you choose).
Shareaza Settings > Networks > eDonkey2000 - Check Auto-Connect/Connect to eDonkey, if you wish.
Configuration Tips :
Gnutella2: Connecting to G2 is very strongly recommended no matter what you download, since it will has a large range of file types and pretty good speeds. It is growing by the day, and takes advantage of all Shareaza’s Advanced Features.
Gnutella1: Only connect to G1 for music and other small files. It offers poor performance on larger files, so you won’t find much other than audio here.
eDonkey2000: Connect to eDonkey for larger files, such as Movies, Software and Games. eDonkey has more users than the Gnutella networks combined, but, due to how the network is designed, offers very poor performance on smaller files. The eDonkey network actually discourages sharing lots of small files, due to its design.
BitTorrent: To download BitTorrent files, you are not required to connect to anything when you are not downloading.
Set your Connection Speed
Shareaza Settings > Internet > Connection - Set the 'Inbound Address' to a number slightly below your rated download bandwidth. Do the same for the 'Outbound Address', setting it just below your upload bandwidth.
Configuration Tips:
If you do not know your rated line speed, check out The Speed Test Page or ask your Internet service provider.
Set the connection speeds to about 80% of your rated numbers, otherwise Shareaza will suck up all of your bandwidth.
Practical Suggestions
If you have gone through all the above tweaks, and your download speed still is not satisfactory, then the following tips should do the trick. These are things that you do over time and don't take affect for a little while. However, these techniques are the ones that all the P2P experts use to get the most performance out of Shareaza and its incorporated networks.
Leave Shareaza Running
Leave Shareaza active for a couple days. If you are downloading from the eDonkey network, it will take time to get to the end of the line in your queue spot. You will see your best download performance after leaving Shareaza on for an extended period of time. Don't judge speed in the first few minutes, because the speed is often much faster towards the middle of a download than at the start.
Tweak your DSL/Cable (Broadband) connection
Sometimes a misconfiguration outside of Shareaza can affect the download speeds. Broadband Reports is a great resource for tweaking and learning more about broadband in general. The site will try and help make your internet connection more efficient. If you do not have broadband, getting it would also be an excellent speed tweak.
Conclusion
Please remember that these are extra tweaks and suggestions to help improve your downloading experience. They may work, but then again, they may not. Don't feel that you are guaranteed speed by reading this, but it probably enhance your Shareaza experience one way or another.
Every single user has a unique situation, and it isn't possible to give each and every one of the users the optimal settings and suggestions. Your best bet is to read carefully and try to figure out the mild science behind all this. It's actually just simple math.
It has become common practice now to post forum threads, asking for more tweaks or "personal settings" and neglecting to read this guide. Please do not do this! The same question is asked over and over, and users do their best to respond to these questions. However, a small mistake in judgement on a settings, and you lose all possible preformance with Shareaza. Plus, there are so many of these threads that they clutter up the forum, and many people just ignore them anyway.
This guide is not perfect, and probably never will be. However, if you have something you'd really like to add, feel free to send a message to any Moderator or Alpha Team Member, and they can help out.
Whether it be telling friends about Shareaza, adding to this guide, participating in the forums, or just raising your upload bandwidth, help the network grow. One day, we can make Shareaza a program as well known as Kazaa, with speeds to match. Until then - keep sharing. Every bit counts.
BONZI is offline
Old 05-03-2005, 01:45 AM   #10 (permalink)
parthbarot's Avatar
biggggggggggggggggg answer man....
i jst ask how to tweak any P2P?
ok thx
regards
& to all ... i no all abt KBps & Kbps ok? so plz.
www.techlads.com
Paarth.
Old 05-03-2005, 11:31 AM   #11 (permalink)
lazy bone
well parth use limewire as your P2P & choose the host with higer bitrate will give you , your desired speed .
multi is offline
Old 05-03-2005, 12:39 PM   #12 (permalink)
ill still suggest you BearShare
PSpwned
Old 05-03-2005, 11:29 PM   #13 (permalink)
Man u can get 8 - 15 Kbps on a dial up for P2P. Man u can even get 100 Kbps. In ur DREAMS
On a Serious note on dial up if u get about 4-5 Kbps would be great. The only solution is a HIGH SPEED NO CAP BROADBAND CONNECTION
Have a Nice Day :)
Mohammed Muchhala, © 2006, All Rights Reserved
http://www.muchhalasworld.com
babumuchhala is offline
Old 06-03-2005, 08:57 AM   #14 (permalink)
The post was about what network to use to get maximum download speed. And some tweaks in shareza. If you use edonkey to download a 3 mb file you will never get good speeds then use gnutella. If you are downloading a 400 mb file use edonkey. They say it goes faster and faster in the middle of download. And the key thing is the more you give the more you get.
BONZI is offline
Old 06-03-2005, 09:12 AM   #15 (permalink)
Laptoping
Sourabh's Avatar
i m on dialup and get a constant download speed of 5.2-5.5 kbps while downloading something from e-mule which has hell lotta sources
but its never less than 4 8)
Sourabh is offline
Old 06-03-2005, 08:47 PM   #16 (permalink)
hack expert's Avatar
well i had dialup before n used to get only 2 measly kbps on kazaa
rite now on cable i get 8 -10 kbps
morpheus is also good kazaa still sucks for me
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
- by Piyush
