Old 28-07-2007, 11:01 PM   #1 (permalink)
ANURAG SHARMA's Avatar
Unhappy PC Hanging after resuming from Hibernating....
When I start my PC again after Hibernating it stucks over to the progress bar and hangs,what's the prob?Plz solve this as I again need to restart from scratch and waste again 20 sec to work again, I am on Win XP with 256 RAM and 25 GB partition.
BE THE BEST EITHER HACKED IN THE QUEST
ANURAG SHARMA is offline
Old 29-07-2007, 10:28 AM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: PC Hanging after resuming from Hibernating....
Try Disabling Hibernating
1. Click "Start" and choose "Control Panel".
2. Select "Power Options".
3. When the "Power Options Properties" multi-tabbed dialog box appears, select the "Hibernate" tab.
4. Uncheck Enable Hibernate
5. Click "OK" to close the dialog box.
Delete Any "hiberfil" from your system (mostly in c:\) and enable Hibernate again
Try that if it works
http://www.host4cheap.org/
Sukhdeep Singh is offline
does ftp support resuming???? tango_cash Software Q&A 8 16-12-2006 05:04 PM
Receive Blue Screen whil resuming from Hibernation g_goyal2000 Software Q&A 1 01-12-2006 08:28 AM
xp not hibernating saurabh kakkar Software Q&A 14 09-09-2006 11:22 PM
ps/2 mouse not responds after resuming standby Aanand Peripherals 2 12-07-2006 07:30 PM
resuming ftp downloads hack expert Internet & WWW 3 17-07-2005 02:07 PM
- by Piyush
