Old 28-07-2007, 09:43 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default Best Encryption Algorithm, Mode & Key Generator?
Hi Guys!
I recently installed BestCrypt 8 and it has different encryprion algorithm like
  • Triple DES
  • Blowfish 448
  • Cast
  • Gost
  • RC6
  • AES (Rijndael)
  • Serpent
  • Twofish
Apart from encryprion algorithm, there is some thing called Mode which again has two diffetent choices :
  • LRW - Tweakable Narrow-block
  • CBC - Cipher-block chaining
Lastly it has something called Key generator with options like:
  • SHA-256
  • KG-Ghost
Now, all this is very confusing. Can you guys tell me which of these should be selected to get the best security.
Thank you.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 28-07-2007, 11:38 PM   #2 (permalink)
slugger's Avatar
Default Re: Best Encryption Algorithm, Mode & Key Generator?
AES (Rijndael) - 256-bit key encryption
Blowfish - 448-bit key encryption
CAST - 128-bit key encryption
GOST 28147-89 - 256-bit key encryption
RC6 - 256-bit key encryption
Serpent - 256-bit key encryption
Triple-Des - 168-bit key encryption
Twofish - 256-bit key encryption
higher d encryption key size more diffcult is it 2 decrypt it by rogue means
it appears dat LRW Iis more secure than CBC
y dont ujust go thru d help file documentation availlable on der website
http://www.jetico.com/
u may click on d Download centre url
slugger is offline
Old 29-07-2007, 09:34 AM   #3 (permalink)
9437077259
go4saket's Avatar
I have already gone through the whole documentation. Its does explain about the algorithms but doesnt say which one is the best.
Win 7 Ultimate
go4saket is offline
mp3 decoding algorithm setharsh Software Q&A 1 05-06-2007 02:28 PM
algorithm maker fanatic Software Q&A 3 25-03-2006 10:17 PM
which software uses the best algorithm for converting DVD fun_theorem Software Q&A 1 28-01-2006 05:10 PM
graphic algorithm shivi4 Graphic cards 1 26-12-2005 10:22 PM
Difference Between FF Ordinary Mode & FF Safe Mode rajas700 QnA (read only) 9 27-08-2005 02:38 PM
- by Piyush
