Higher configs based on an S939 CPU + mobo will fall outside your budget unless you reduce the other items, which would be meaningless. That's why I suggested an S754 system.
I don't have the current price for the Asus K8V series but it's higher than that of the MSI K8MM-ILSR.
While the K8V-X does have some extra features, keeping your budget in mind, ask yourself if you need those features. Are you really going to use the 2 extra PCI slots, 1 extra RAM slot and Gigabit LAN ?
Also consider the fact that the MSI board has Firewire (IEEE1394) built-in. And if gaming is not important, you can also save the cost of a graphics card.
nVidia chipsets are generally regarded as the best for AMD systems, but VIA comes a close second.
PCI-E x16 slots are for the newer generation of graphics cards.
AFAIK, at present they are incorporated only on the more expensive S939 boards.
N.B.: To those who PM'ed me about where to buy in Calcutta/Kolkata, I'd like to make it clear that my sources are NOT some black market operations. They are legitimate retail outlets that, within my experience, have been reliable over the years.
Their prices are not always the cheapest (no seller can offer the lowest price in everything), but they are usually very reasonable, and are
sometimes lower than those of many shops in Bangalore, Lamington Road in Mumbai or Nehru Place in Delhi.
I repeat that I will let my sources be known only to those who are willing to give me their email address and other details in their PM.
