Old 26-07-2007, 11:08 PM   #1 (permalink)
Default please help !! any one using tata indicom dialup
hi friends
i am using the dialup for 6 months, from past month i am facing a problem,
after connecting to internet, it works fine for 20 to 30 seconds and then the data transfer stops, but the connection remains, and i have to diconnect and connect again, this is the repeating problem.
when i called 121(call center) they tell to do some adjustments in modem, and recreate the dialer, restart the system. it use to work only for few days, and again the same problem repeatedly.
one day an engineer from tata indicom called me and said that it is happening because of spyware or virus, but when i scaned the whole system with spybot search and destroy and avast antivirus i found nothing. even then i formatted and reinstalled my windows xp.
still the same problem, does this happen because of spyware or virus ?
does any one have solution for this,
thankyou
harikrishnat is offline
Old 26-07-2007, 11:26 PM   #2 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Question Re: please help !! any one using tata indicom dialup
just try to do this as soon as you get connected
see the server ip address in the connection window in taskbar & ping the server
How to ping
Go to run
Type "ping 1xx.xxx.xx.xxx -t" without quotes where 1xx.xxx.xx.xxx will be your server's ip address
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 26-07-2007, 11:31 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: please help !! any one using tata indicom dialup
Yep. Its happening bcoz of "Dormancy". Its a CDMA phone feature which cause the disconnection if there is no activity, so that u can attend calls. Using PING will help u and use following command for better speed:
Ping -t 203.197.12.30
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 26-07-2007, 11:32 PM   #4 (permalink)
How to ping
Go to run
i can find only client ip address how to find server ip address, and in task bar it is written TATA indicom....
Old 26-07-2007, 11:33 PM   #5 (permalink)
Microsoft MVP
^^ Yep. In TATA connection it doesnt show IP address. Use the command given by me.
Old 26-07-2007, 11:34 PM   #6 (permalink)
thank you vishal gupta,
Old 28-07-2007, 10:41 PM   #7 (permalink)
no friends it didn't help much,
even now also i face the same problem,
after a minute or two i get 'request timed out' thats it no data transfer, again i have to disconnect and dial again.
do you think it is happening because of spyware or virus, as said by tata indicom engineer.
even now to post this i am dialing third time.
Old 28-07-2007, 10:51 PM   #8 (permalink)
The Unknown's Avatar
Don't believe those mad ppl. What they say may hardly come true for 5 out of 10 ppl. I also had this problem. I guess ur CDMA phone is AXW-P800 or AXW-P830. This happens with AXW-***. Tell them to replace the phone.
KDE on ArchLinux
The Unknown is offline
Old 28-07-2007, 11:00 PM   #9 (permalink)
Microsoft MVP
"Request Timed Out" is not a problem in ur phone. It means u r getting very poor net speed.
Old 29-07-2007, 02:25 PM   #10 (permalink)
I had AXW-P800. It worked 4 arnd 3 mths then i had the same prob. Then it crashed (dunno wat happened). They replaced it with another AXW-P800 then it worked fine.
KDE on ArchLinux
help me to configure tata indicom dialup in ubuntu. sav_more Open Source 7 04-02-2007 08:54 PM
Tata Indicom (help) Chirag QnA (read only) 7 19-09-2005 12:17 PM
TATA Indicom Walky ? Sarwesh QnA (read only) 2 15-09-2005 11:47 PM
Tata Indicom Internet premsharma Mobiles and Tablets 6 12-09-2005 01:02 PM
- by Piyush
