Old 26-07-2007, 10:25 PM   #1 (permalink)
Default Want to Upgrade RAM
Hi all ..
I have a P4 processor with ASUS mobo, 256 mb 333MHz DDR RAM. I find the system slow and want to upgrade RAM to 512 Mb. Whats the best option. My supplier says it will be dificult to find this RAM. So whats the option ... Kindly comment
Thanks
harmads is offline
Old 27-07-2007, 12:26 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Want to Upgrade RAM
U can add only the same type RAM with same frequency.
ravi_9793 is offline
Old 27-07-2007, 01:08 AM   #3 (permalink)
bajaj151's Avatar
You HAVE to add new ram of same frequency for the smooth and better performance.
Presently, which ram you are using ??
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now
Old 27-07-2007, 07:40 AM   #4 (permalink)
Why not use 400 MHz Ram which should work @ 333 along with the present stick.
V.Prem Kumar
janitha is offline
Old 27-07-2007, 09:23 AM   #5 (permalink)
Om Ma Ni Pä Me Hum
phuchungbhutia's Avatar
need to ask whether the memory size has to be same or only the frequency.... i know that the freq has to be same but any other reqmnt....
... sorry for cutting in
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
phuchungbhutia is offline
Old 27-07-2007, 09:43 AM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
only frequency and type of memory.You can add different merory size RAM
Old 27-07-2007, 05:25 PM   #7 (permalink)
I am not getting 333 MHz(as per my original RAM) . However, in 400 MHz both 256 and 512 Mb are available. What will be the best option ?
1. 256Mb/333Mhz + 256Mb/400Mhz or
2. 256 Mb/333 Mhz + 512 Mb/400 Mhz or
3. 512Mb/400 Mhz.
Since my Mobo came with RAM of 333Mhz, will the change over to 400Mhz not cause any conflict..??
Thanks
harmads is offline
Old 28-07-2007, 11:56 AM   #8 (permalink)
bajaj151's Avatar
I wud suggest u to sale out ur present 256mb@333mhz.... and go for single 512mb@400mhz.
Old 28-07-2007, 04:20 PM   #9 (permalink)
Thanks for the inputs guys..very helpful.
Bajaj151, ok that makes sense.. will do that.. But since my original RAM was 333, hope 400 will work ok on my mobo ??
harmads is offline
Old 28-07-2007, 06:19 PM   #10 (permalink)
bajaj151's Avatar
ya...400mhz will definately work fine with better performance than that of 333mhz
tell me the mobo you using ??
Old 30-07-2007, 11:35 AM   #11 (permalink)
Om Ma Ni Pä Me Hum
i have asus a8v mx mobo amd 64 3000 venice
Memory spec:
- Support for the dual-channel DDR266/333/400 MHz memory,
- Two 184-pin DDR DIMM memory modules.
- Maximum memory capacity 2 GB.
now i want to know the diff bw DDR and DDR2
will there be prob if upgrading my memory with DDR2 ram ...
what are the options that i hav
Old 31-07-2007, 12:21 AM   #12 (permalink)
The Frozen Nova
casanova's Avatar
U r having only a 256MB 333MHz RAM Stick. You do better exchange it for a 512MB stick of atleast 533MHz. You wont regret it
www.nerdweed.blogspot.com
casanova is offline
Old 04-08-2007, 12:09 PM   #13 (permalink)
bajaj151's Avatar
@ Harmad
which mobo you are using ??
@phuchungbhutia
Ur mobo do not support ddr2, so u cant upgrade it to ddr2 ram...
And for difference,
chk this: http://www.xbitlabs.com/articles/mem.../ddr2-ddr.html
Old 04-08-2007, 01:20 PM   #14 (permalink)
Did you mean "512MB stick of atleast 333MHz"?
V.Prem Kumar
janitha is offline
Old 06-08-2007, 12:30 AM   #15 (permalink)
The Frozen Nova
casanova's Avatar
Nah, I meant what I said. 533MHz as I said to exchange it and not to add it.
casanova is offline
Old 06-08-2007, 07:36 AM   #16 (permalink)
But he has DDR RAM and most probably his Mobo will not support DDR II.
V.Prem Kumar
janitha is offline
Upgrade woo-hoos to Upgrade blues. Help! mightyboosh Hardware Q&A 1 27-11-2006 12:14 AM
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
graphic card upgrade(PCI) or motherboard upgrade? thetopcyborg Graphic cards 5 13-01-2006 02:32 PM
Best Upgrade Possible d Hardware Q&A 7 14-12-2005 10:24 PM
Upgrade my PC ECE0105 QnA (read only) 15 01-07-2005 11:27 PM
- by Piyush
