24 FPS Stands for 24
Frames
Per
Second
It is considered to be the minimum frequency of displaying frames required to create the optical illusion of smooth unhindered motion thus used as a general standard in the animation indusrty.
Generally 12 FPS is considered to be the bare minimum. It is used where movie size is a concern [ie webpages.]
Your eye can "hold" images for 0.1 seconds. This is called persistance of vision. Thus is 10 images are flashed across your eyes in a second they will "overlap" and cause the sensetion of animation. 12 to be safe.
^^ This should give your something to google on ^^
