Old 26-07-2007, 07:16 AM   #1 (permalink)
rajat22's Avatar
Talking K-Lite Mega Codec Pack 3.3.0
K-Lite Codec Pack is a collection of codecs, DirectShow filters and tools. Codecs and DirectShow filters are needed for encoding and decoding (playing) audio and video formats. The K-Lite Codec Pack is designed as a user-friendly solution for playing all your movie files. With the K-Lite Codec Pack you should be able to play all the popular audio and video formats and even some rare formats.
The K-Lite Codec Pack always very up-to-date with the newest (and/or best) versions of the components. The installation is fully customizable, meaning that you are able install exactly those components that you really want. Uninstallation removes all files and registry entries created by the pack. It is extremely easy to make a fully customized unattended installation. It tries to avoid potential problems with existing codecs and even fixes some problems. The pack is able to detect broken codecs and filters on your system, and remove them for you. It is a very complete package, containing everything you need to play your movies. Suitable for both novice and expert users. The K-Lite Codec Pack works on Windows 2000/XP/2003/XP64/Vista.
Changes from K-Lite Mega Codec Pack 2.2.5 to K-Lite Mega Codec Pack 3.3.0 :
- Updated Media Player Classic [version 6.4.9.0+ | Mod by Casimir666 v1.0.9.0]
- Updated ffdshow to revision 1371
- Updated Xvid to version 1.1.3
- Added MainConcept MPEG decoder [version 1.0.0.78]. This will be used only for decoding MPEG-1
- Updated Codec Tweak Tool
- Lots of small changes and improvements
- Increased version to match the version of KLCP
Homepage - http://www.codecguide.com
Download K-Lite Mega Codec Pack
http://rapidshare.com/files/44997564...ecPack_330.exe
Mirror
http://download.betanews.com/downloa...lmcodec330.exe
Mirror
ftp://majorgeeks.mirror.internode.on...lmcodec330.exe
Use Right-click on Download and "Save Target As..."
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
Old 31-07-2007, 09:02 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
Default Re: K-Lite Mega Codec Pack 3.3.0
Off-topic posts have been removed. Please keep the discussion pertinent to the topic and don't make it personal.
Sourabh is offline
Old 01-08-2007, 10:38 PM   #3 (permalink)
drsethi's Avatar
Really a must for Windows users.
drsethi is offline
Old 01-08-2007, 11:27 PM   #4 (permalink)
in your face..
karnivore's Avatar
This version, like the previous one, for some reason, doesn't work properly with TMPGEnc 4 Express. The audio mismatch can't be corrected using this version. However older versions of K-lite work fine.
karnivore is offline
Old 02-08-2007, 12:50 AM   #5 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
^^thnx for the heads-up....thats y am happy with ver 1.6
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 05-08-2007, 09:50 PM   #6 (permalink)
rajasekharan's Avatar
hey, will this work for quicktime stuffs in "vista", have they corrected the problem of "frame getting stuck"...
till 2.2.0 lastly i downloaded , they have not sort the problem , i gave up downloading .
well , it does not appear for every movie , but for major of my collection.
Make a day good , and another day good , and another ...a happy lad is "born" from you :)
rajasekharan is offline
Old 16-08-2007, 12:08 PM   #7 (permalink)
Always Fresh!
shri's Avatar
why isn't quicktime alternative bundled together these days?
BE YOURSELF :)
http://everythingoutthere.co.cc
shri is offline
K-Lite Mega Codec Pack 1.71 rajat22 QnA (read only) 3 14-04-2007 03:38 PM
K-Lite Mega Codec Pack 1.61 rajat22 QnA (read only) 4 21-11-2006 03:21 PM
K-Lite Mega Codec Pack 1.60 rajat22 QnA (read only) 8 07-11-2006 09:19 PM
K-Lite Mega Codec Pack 1.37 rajat22 QnA (read only) 4 26-08-2005 11:17 PM
- by Piyush
