thanks for the reply guys.....ok heres the situation
it does not read any disks......not even CDrs.....It shows up properly in the device manager........the DVD region shows still 4 changes remaining........NO I have not tried to clean with a lens cleaner/ I will in a couple of days...........this has been happening for the last 2 months..........also I did not find the firmware for samsung sm352n (model)
please let me know if there are any other suggestions
just check event viewer to see if u get any error msgs after u place a dvd in the drive . while trying to read , do u get too much noise and check if ur drive gets over heated as well . if so , try placeing it in another bay or remove the drive from the cabinet and try running it from the outside .
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
ok try this after checking the above stuff i have posted . in device manager . uninstall the dvd from the list and also , the primary or secondary ide controller , depending on which one has the dvd connected to it and restart . let it install the dvd again and reboot . once ur back in , in device manager ide controller , change settings to use dma if available for the drive .
thanks man.after I uninstalled and reinstalled it it seems to be working.........I have kept my fingers crossed and if it starts behaving like that again I will have to take it to the vendor........
will keep this thing posted
well as this regarding sasung dvd rom question thats why i am posting my question here..
my samsung dvd try to read disk at the time of boot up when the boot from the CD option is desabled
ya i mean it..... its boots in...... strange problem..... i dont know whether i updated my bios (v1006) thats why it giving a problem or not.... i am on a7v8xmx-se mobo....
Check the sequence of boot i.e. FDD, then HDD, then CD/DVD Rom
AMD64 2800+,MSI K8N Neo Plat Edt,Transcend 512x2 DDR400,Powercolor 9600Pro 256MB,Benq 17" Monitor,Seagate SATA 80GB X 2 (RAID 0),Seagate SATA 320GB,Sony DRU-820,Creative Live!5.1,Creative Inspire 5200
