Old 25-07-2007, 04:25 PM   #1 (permalink)
direfulsky's Avatar
Exclamation OS INSTALLATION problem....
I bought a new 80gb seagate hdisk..partitioned successfly...tried to install XP service pack 2(of course pirated)...after formattin,copyin list of files successfully done..after restartin instead of installation i got a blue screen with
"A RECENT HARDWARE/SOFTWARE PROBLEM OCCURED...and list of options such as SAFE MODE so n so..but nothing worked..sytem automatically getting restarted..
I EVEN TRIED WITH SOME OTHER XP SERVICE PACK2 CDs...am gettin the same error msg...
thanks..
shoot for moon even if u mis u land up amoung stars...
direfulsky is offline
Old 25-07-2007, 09:09 PM   #2 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Default Re: OS INSTALLATION problem....
Only 1 Solution , Go For Genuine Windows ! thats all .... !
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 25-07-2007, 09:37 PM   #3 (permalink)
Jai Suresh
lywyre's Avatar
Press F8 when the system boots
and from the Windows Boot Menu choose the option that says "Disable automatic restart .....", and proceed to boot. Now when your system crashes you will get a blue screen of death. Here note the error message and the error code and look it up in google or microsoft knowledge base.
Most likely that you need to change your data cable also.
This happens with Genuine Windows also !
lywyre is offline
Old 25-07-2007, 11:26 PM   #4 (permalink)
direfulsky's Avatar
i did got the promlem solved...just my changing the data cable.. thanks guys..
as far as geniune windows is concerned..i wish i could..
but i cant afford.. to pay for that.
Old 25-07-2007, 11:38 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
congrates..ur problem is solved.The main cause of such problem is either BAD hard disk or BAD data cable.
And for genuine...why dont you buy starter edition of win XP.They are very cheap.
ravi_9793 is offline
Installation problem.... devilzdad Open Source 9 09-03-2007 11:37 PM
USB Hub Installation Problem speedyguy Hardware Q&A 5 26-06-2006 12:47 AM
XP Installation problem sknowonweb Software Q&A 8 12-11-2005 12:34 AM
Win 98 Installation Problem arifmohd786 Software Q&A 6 13-07-2005 11:43 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by Piyush
