Old 03-03-2005, 01:19 AM   #1 (permalink)
dOm1naTOr's Avatar
Default Xtra cooling fan don't show rpm
I bought a new additional cooling fan for my machine.
But it had only 12v molex power connector, and cannot be connected to the pin in MB for the fan connector.
So I'm only able to know the speed of my stock CPU fan only .
How can I know the speed of my new fan?????
dOm1naTOr is offline
Old 03-03-2005, 09:33 AM   #2 (permalink)
darklord's Avatar
Well all you can do is search for a FAN having this support.There is nothing you can do.
darklord is offline
Old 03-03-2005, 09:39 AM   #3 (permalink)
dOm1naTOr's Avatar
ANYWAY THANKS FOR YOUR REPLY
How much does a fan with the feature cost? Any idea??
Old 03-03-2005, 03:38 PM   #4 (permalink)
darklord's Avatar
Should be around 400 for a Coolermaster
darklord is offline
- by Piyush
