Old 22-07-2007, 11:33 PM   #1 (permalink)
Default Adding A Harddrive Will Affect The Performance ?
My System Ic Compaq Presario 1105il (amd Athlon Xp 2400+) With 40 Gb Hard Drive. Now I Want To Add One More Harddrive As Slave With
160 Gb Capacity. Will It Affect The Performance Of The System Or Affect The Cooling Effect Of The System? Why I Am Asking This Question Is The System Is A Branded One And Came With One 40 Gb Harddisk Only.
jaisrigopi is offline
Old 22-07-2007, 11:39 PM   #2 (permalink)
slugger's Avatar
Default Re: Adding A Harddrive Will Affect The Performance ?
there shud b absoultely no problem in addin another HDD 2 ur computer
looking @ ur pro it appears 2 me dat it is no longer under warranty, but if it is just check if by adding another hdd u nullify ur warranty or not
btw mkaing d 160 GB ur primary master and 40 GB ur secondary slave it a gud ida
slugger is offline
Old 23-07-2007, 12:38 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
I dont think. adding another hard disk will affest system performane.But yeah..ur system boot time will increase by few seconds.
ravi_9793 is offline
Old 23-07-2007, 01:00 AM   #4 (permalink)
Turn The Page
pannaguma's Avatar
Location: The name of the place where I live is too big to fit in this place, so I am not mentioning it !!!
i added a new 80GB HD as slave to a 3 and a half yr old 20GB HD. (both seagate) and within a month the 20GB HD crashed. maybe some one can enlighten me as to why it could have happened?
This Space Has Been "RESERVED" !!!
pannaguma is offline
Old 23-07-2007, 09:25 AM   #5 (permalink)
The Frozen Nova
casanova's Avatar
Sometimes computers behave funny. Last time I added a HDD my PC became fast.
It will degrade the performance slightly but nothing to worry.
1. There will be a lttle more power consumption
2. Little more heat
This should not be an isssue. Go on with ur space enhncement.
www.nerdweed.blogspot.com
casanova is offline
Old 24-07-2007, 12:41 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
no problem @ all ........
... W H O T ...
ax3 is offline
destroy Harddrive choklate_007 Hardware Q&A 9 27-11-2006 12:02 AM
Back up your harddrive including the OS rajiv.b QnA (read only) 12 10-04-2006 11:53 AM
Segate harddrive crashed willrock QnA (read only) 3 19-07-2005 10:12 PM
ATA133 Cable for Harddrive! Krazy_About_Technology QnA (read only) 5 25-02-2005 05:18 AM
formatting dual os harddrive?? mal_e QnA (read only) 15 21-01-2005 11:10 PM
- by Piyush
