Old 22-07-2007, 10:30 PM   #1 (permalink)
Distinguished Member
anandk's Avatar
Arrow Minimalist Explorer Breadcrumbs Tool for XP.
Rather than navigating step-by-step through your folder hierarchy -- view your folders quickly and go directly to any location with a single click.
Explorer Breadcrumbs is an add-in for Windows Explorer which contains a contextual series of buttons that allows you to quickly see and navigate through the entire folder hierarchy without leaving the current window.
http://minimalist.com/software/ExplorerBreadcrumbs/
came across this on the net. not used it, btw, as i use vista...
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 22-07-2007, 11:18 PM   #2 (permalink)
Wise Old Crow
blueshift's Avatar
Default Re: Minimalist Explorer Breadcrumbs Tool for XP.
Cool. Thanks anandk!
http://twitter.com/blueshift155
blueshift is offline
REVIEW: SIW System tool <A good tool you ever need> Kiran.dks Reviews 25 01-05-2007 02:08 PM
[Windows Explorer Prob.] Explorer opens each folder in a new window //siddhartha// Software Q&A 21 19-07-2006 01:24 PM
Tv Tool V9.5.5.5 c4u QnA (read only) 2 02-09-2004 10:33 PM
Internet Explorer Repair Tool yaaara_daaa_tashannn Internet & WWW 2 09-08-2004 11:01 PM
- by Piyush
