Old 22-07-2007, 08:35 PM   #1 (permalink)
Default dvd-r or dvd+r media?
I bought 10 sony dvd-r discs. Later i found from the net that dvd+r is the best format and it will also last longer. I read stuff like 33% of the data is unprotected in Dvd-r and few other negative things from http://adterrasperaspera.com/blog/20...rchival-media/ . I want to write games, softwares and movies onto these dvds. Shall i go ahead and burn with dvd-r's or should i buy dvd+r's? kindly advice, thanks in advance.
casual_gamer is offline
Old 23-07-2007, 01:13 AM   #2 (permalink)
Turn The Page
pannaguma's Avatar
Location: The name of the place where I live is too big to fit in this place, so I am not mentioning it !!!
Default Re: dvd-r or dvd+r media?
AFAIK + means more compatibility/reliability and - means more speed.
This Space Has Been "RESERVED" !!!
pannaguma is offline
Old 23-07-2007, 08:43 AM   #3 (permalink)
Hell Sucks!!!
See i have had been using -R from almost last 2 yrs, some good quality and some other cheap ones. I have lost some chunks of data on the cheap DVDs in about an year but the good quality ones are goin and they are goin strong.
So my advice to u is to use the format which is most compatible with ur Writer. Just try both of these, +R n -R and diffrent brands. Then write it and do a disk quality check by Nero speed(There are others too like Kprobe etc, bt i find this one quite good)
BTW Sony are quite good as compared to other medias available in India in their price band.
And fo me Sony DVD+R with media code D21 has been the best with my writer
ashu_dps is offline
Old 23-07-2007, 04:29 PM   #4 (permalink)
royal's Avatar
Wink Re: dvd-r or dvd+r media?
DVD+R supprts overburning
royal is offline
play real media (.rm) files in windows media player mneo Tutorials 7 10-07-2007 08:30 PM
Media hype created by Spanish media over Kaka Voldy Fight Club 1 02-07-2007 12:26 AM
wat Media was used ? vinyas QnA (read only) 8 23-08-2006 04:07 AM
HP Windows Media Centre License/Boot Media problem sysengnet Software Q&A 1 06-05-2006 04:36 PM
Best CD-R / CD-RW MEDIA klinux QnA (read only) 15 12-10-2004 12:03 AM
- by Piyush
