I want to develop a software with the following properties / functions:
1. I will design a back-end database (somewhat big) initially.
2. I need to create a front-end GUI for interactivity. It should either be a HTML page or a windows application.
3. I need to integrate the two of them in such a way that the software should allow users to view, edit, and modify the already created database from their computers.
Please suggest the best tools I require. I already have the database created.
Is it possible to make a "standalone" program of the above? So that the users need not have the database program but can still add to it just using the front-end...?
Do I require a special program to package the application (in case its a windows program)?
Thanks for any help you might be able to offer.
Chandra.
