LinkBack (1) Thread Tools Search this Thread Display Modes
Old 03-03-2005, 01:06 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Please help!!!!!!!!! -Could not perform end of disc at once
Hi guys,
I am trying to burn my DVDs but 90% of them are failing giving me the error message "Could not perform end of disc at once". Can someone please help me out with this?
I have a Sony DRU-700A DVD Writer and using Nero 6.3..
Following are the logs:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'D:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 7/28/2004 4:51:12 PM
Nero version: 6.6.0.0
Recorder: <SONY DVD RW DRU-710A> Version: BY03 - HA 1 TA 0 - 6.6.0.0
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <SONY CD-RW CRX225E >Version: QYB1 - HA 1 TA 1 - 6.6.0.0
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SV2042H atapi Port 0 ID 0 DMA: On
DiskPeripheral : SAMSUNG SV8004H atapi Port 0 ID 1 DMA: On
CdRomPeripheral : SONY DVD RW DRU-710A atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SONY CD-RW CRX225E atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
SONY DVD RW DRU-710A K: CDRom0
SONY CD-RW CRX225E L: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 56623104 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 375MB (384356kB)
Free physical memory: 168MB (172692kB)
Memory in use : 55 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
1.3.2005
ISO compilation
9:05:33 PM #1 Text 0 File Isodoc.cpp, Line 6170
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 2 (Max. of 31 chars)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
9:05:33 PM #2 Text 0 File Reader.cpp, Line 127
Reader running
9:05:33 PM #3 Text 0 File Writer.cpp, Line 122
Writer SONY DVD RW DRU-710A running
9:05:33 PM #4 ISO9660GEN -11 File geniso.cpp, Line 3286
First writeable address = 0 (0x00000000)
9:05:34 PM #5 Text 0 File Burncd.cpp, Line 3119
Turn on Disc-at-once, using DVD media
9:05:34 PM #6 Text 0 File DlgWaitCD.cpp, Line 256
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2215759 (492:23.34, 4327MB)
9:05:34 PM #7 Text 0 File DlgWaitCD.cpp, Line 268
Write in overburning mode: NO (enabled: CD)
9:05:34 PM #8 Text 0 File DlgWaitCD.cpp, Line 2310
Recorder: SONY DVD RW DRU-710A, Media type: DVD-R
Disc Manufacturer: OPTODI - SCR004
Disc Application Code: 64, Disc Physical Code: 193
9:05:34 PM #9 Text 0 File DlgWaitCD.cpp, Line 430
>>> Protocol of DlgWaitCD activities: <<<
9:05:34 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 844
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2215760 (2215760) = #2215760/492:23.35
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2215760 blocks [SONY DVD RW DRU-710A]
9:05:36 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 1045
Prepare recorder [SONY DVD RW DRU-710A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4537876480, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2215760 | lead-out | 1 | 0x00 | 0x41
9:05:36 PM #12 Phase 24 File dlgbrnst.cpp, Line 1861
Caching of files started
9:05:36 PM #13 Text 0 File Burncd.cpp, Line 4135
Cache writing successful.
9:05:36 PM #14 Phase 25 File dlgbrnst.cpp, Line 1861
Caching of files completed
9:05:36 PM #15 Phase 36 File dlgbrnst.cpp, Line 1861
Burn process started at 4x (5,540 KB/s)
9:05:36 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
9:05:36 PM #17 Text 0 File dlgbrnst.cpp, Line 1719
Set remaining time: 13:44,875 (824875ms) -> OK
9:05:36 PM #18 Text 0 File DVDR.cpp, Line 1955
Recording mode: Sequential Recording Mode for Multisession
9:05:36 PM #19 Text 0 File Mmc.cpp, Line 20542
Set BUFE: Power-Burn -> ON , Generic write control : OFF
9:05:37 PM #20 Text 0 File DVDR.cpp, Line 2096
Start write address at LBA 0
DVD high compatibility mode: Yes
9:05:37 PM #21 Text 0 File Cdrdrv.cpp, Line 8259
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
9:05:37 PM #22 Text 0 File DVDR.cpp, Line 4841
Drive: SONY DVD RW DRU-710A
Book Type request: Physical disc type
Changing the book type was finished with error code: 0
9:19:37 PM #23 Text 0 File WriterStatus.cpp, Line 116
<SONY DVD RW DRU-710A > start writing Lead-Out at LBA 2215760 (21CF50h), lenght 0 blocks
9:19:38 PM #24 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
9:19:38 PM #25 Text 0 File DVDR.cpp, Line 2338
EndDAO: Last written address was 2215759
9:19:42 PM #26 Phase 133 File dlgbrnst.cpp, Line 1861
Writing short lead-out
9:19:51 PM #27 SCSI -1176 File Cdrdrv.cpp, Line 1175
SCSI Exec, HA 1, TA 0, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x72
Sense Qual: 0x02
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x02
9:19:59 PM #28 Text 0 File dlgbrnst.cpp, Line 1719
Set remaining time: 0:00,000 (0ms) -> OK
9:19:59 PM #29 CDR -1176 File ThreadedTransferInterface.cpp, Line 1774
Session fixation error
SONY DVD RW DRU-710A\H1 T0
9:19:59 PM #30 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1774
Could not perform end of Disc-at-once
9:19:59 PM #31 Text 0 File DVDR.cpp, Line 2338
EndDAO: Last written address was -1
9:19:59 PM #32 Text 0 File dlgbrnst.cpp, Line 1719
9:19:59 PM #33 Text 0 File dlgbrnst.cpp, Line 1719
9:19:59 PM #34 Phase 38 File dlgbrnst.cpp, Line 1861
Burn process failed at 4x (5,540 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 12/21/2004 12:07:14 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 8/23/2001 12:00:00 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
libinbenny is offline
Old 03-03-2005, 08:21 AM   #2 (permalink)
I'll just go through the basics
- simple steps u can try first , get a dvdrw (if there any ) and try burning with that , just for tests , so as not to waste cash on new dvdr
- have u run chkdisk / defrag lately , switched AV off while burning
- in ur sys bios settings the status of both cdrw and dvdrw , are they both using the same transfer settings ie udma 2 or udma 5 ? if not , change it to the same , and lower settings .
- under ide controller in device manager in xp , are they both running on "dma if available" , if so which transfer mode .
- what wattage is ur power supply ?
- i assume ur cdrw is working fine , so remove the cdrw and see if ur able to burn with the dvdrw alone
if u have the time go through the steps , it might seem a long process , but once u get ur dvdrw working u can have hours of writing without worries .
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 03-03-2005, 04:47 PM   #3 (permalink)
swatkat's Avatar
if u r having burning softwares Nero and Roxio, it's better u uninstall any one (Roxio) completely.....
also run Disk Defragmenter....and burn at a lower speed....
http://swatrant.blogspot.com/
swatkat is offline
Old 05-03-2005, 06:45 PM   #4 (permalink)
I have no problems writing CDs/ CDRW.. I have a CD Writer and a DVD Writer attached to my system. And there is absolutely no problem in burning a DVD. Its just during writing short lead out ie after burning the data that the burning fails.. If it were mid-way then i could understand. anyways ill try these steps.. I only have nero installed.. Havent used Roxio due to it system hungry requirements. Any other DVD burning software that i could use?
Old 05-03-2005, 07:23 PM   #5 (permalink)
could be media incompatibilty as well ...
try different media
man i had posted this huge solution for a similar problem i cant seem to find it .... ill post it as soon as i do !
No Mercy, No Limits.
theraven is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/6361-please-help-could-not-perform-end-disc-once.html
Clix This thread Refback 22-09-2010 07:48 PM
