Old 22-07-2007, 04:59 PM   #1 (permalink)
Default Need Help
Hi all..
I request experts to help me sort the following problem out:
When I boot my PC, it goes to Disk Checking mode. This has been happening for some days. The message says "Checking for inconsistency in one of the disks". This message is same(or similar) as the one that comes when you have an improper shutdown.
This was not happening earlier.
Thanks
harmads is offline
Old 22-07-2007, 06:06 PM   #2 (permalink)
The Unknown's Avatar
Default Re: Need Help
Do you have an UPS for your computer? Do you shutdown your pc properly? If you don't have one UPS, go and buy one now before something big damage occurs.
KDE on ArchLinux
The Unknown is offline
Old 22-07-2007, 06:24 PM   #3 (permalink)
D i s t i n c t l y Ahead
saurabh kakkar's Avatar
Smile Re: Need Help
Originally Posted by harmads
Hi all..
Thanks
do this :
all you have to do is find out which Drive your having the problem on (conicider D) and then go to RUN and type:
>chkdsk D: /r
*Note replace the D with whichever letter yours is
then when it asks you yes or no say YES
And everythings will be fixed
hope this will help
saurabh kakkar is offline
Old 22-07-2007, 06:32 PM   #4 (permalink)
Originally Posted by saurabh kakkar
do this :
>chkdsk D: /r
hope this will help
But this check normally comes either if the disk-check has been scheduled or the shutdown is improper.
KDE on ArchLinux
Old 22-07-2007, 06:38 PM   #5 (permalink)
Yeah, right. But normally windows chkdisk check only in 3 stages and when optional /r is given the hard drive is checked for some 5 stage tests.... and this cud really help in author's case.
dabster is offline
Old 22-07-2007, 06:41 PM   #6 (permalink)
Yeah could be. I have forgot windows since i have been using linux. I remember only some of it. I tell what is remaining in my brain. I am never again going to use windows. If i use, it will be either linux or any other OS but not any MS product.
KDE on ArchLinux
Old 22-07-2007, 07:00 PM   #7 (permalink)
yup cool, But it is the first OS which you used when u were a child. which made u interested in comp, aint this way
@author: if the partition is Fat and you have linux live cd, you can use fsck which can check the file system with utmost perfection.
dabster is offline
- by Piyush
