Old 22-07-2007, 12:14 PM   #1 (permalink)
godling's Avatar
Post Portable Hard Drive
Need a portable USB hard drive which has a REALLY SMALL FORM FACTOR.
Can someone advice which is the smallest of the lot? Capacity is not a problem.
Anything close to 40GB or more will do. But it must be hard drive based and not
a flash pen-drive, and must be really really small!
godling is offline
Old 22-07-2007, 03:41 PM   #2 (permalink)
NP : Crysis
xbonez's Avatar
Default Re: Portable Hard Drive
u can get a laptop hard disk in an external 3.5" case. the size is approx that of a credit card and about 1/2 and inch thick
40 GB - rs. 2.2k
80 GB - rs 2.7k
xbonez is offline
Old 24-07-2007, 10:45 AM   #3 (permalink)
godling's Avatar
Is 3.5" the smallest available? Or are 2.5" casings also available?
godling is offline
Old 24-07-2007, 11:03 AM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
This would be the size, of which xbonez was pointing to...
Available at Rs. 2.5k to 2.7k depending on the place u go
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 24-07-2007, 11:06 AM   #5 (permalink)
NP : Crysis
xbonez's Avatar
2.5" casings aren't available since a laptop hdd wouldn't fint inside it (they're 3.5"). if u want yet smaller ones, u can get branded portable hdds (not the laptop hdd in case type). they'll be much more expensive.
@choto_cheeta : yes, thats exactly what i was referring to. i got a 80gb hdd for 2.4k and the external case (Zippys) for rs200. total rs 2.6k
xbonez is offline
Old 24-07-2007, 05:14 PM   #6 (permalink)
royal's Avatar
Question Re: Portable Hard Drive
But we all know a laptop hdd fits inside a 2.5" portable drive
The regular hdds require 3.5" drive.
royal is offline
Old 24-07-2007, 06:52 PM   #7 (permalink)
NP : Crysis
xbonez's Avatar
oh sorry! the casing i'm talking about is 2.5". got confused and checked on the casing. its a 2.5" external case wth a laptop hdd inside
xbonez is offline
Old 25-07-2007, 04:31 PM   #8 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
get a laptop hard disk & 2.5" external case & have fun ............
cheapest way 2 create an external usb storage device .........
with lotta space ......
... W H O T ...
ax3 is offline
USB Cable for Portable Hard Drive abhijitroy Hardware Q&A 4 20-01-2009 06:40 PM
Portable Hard drive? *GandaBerunda* QnA (read only) 1 30-04-2007 11:44 AM
Making portable hard drive blademast3r Hardware Q&A 8 24-02-2007 06:03 PM
Data recovery help needed for flashtrax portable hard drive kevin_476 Hardware Q&A 1 18-01-2007 12:16 PM
Portable hard disk Angad singh Hardware Q&A 4 28-11-2006 09:32 PM
- by Piyush
