Old 21-07-2007, 09:45 PM   #1 (permalink)
Formerly Spashy
Sparsh007's Avatar
Default Help With Installation Of Hard Drive
i recently got a Seagate Barracuda Model Number: ST3300820AS
Model Site On Seagate http://tinyurl.com/33aw37
i got the hard disk but no screws wires and stuff
i wnt to kno how to install it
if any1 cloud plz help me out thnx...
World Cup T20 News: http://wct20talk.com
Sparsh007 is offline
Old 21-07-2007, 09:49 PM   #2 (permalink)
slugger's Avatar
Default Re: Help With Installation Of Hard Drive
u dont need wires 2 attach a hdd 2 ur cabinet
wat u need is a small packet of philip head screws to do d job
go 2 any local comp dealer and ask 4 a packet of dose
he shud give u a small packet of such screw, probably contain 20-25 such screws
slugger is offline
Old 21-07-2007, 09:53 PM   #3 (permalink)
Formerly Spashy
Sparsh007's Avatar
1.Thnx for Quick reply
2.what type of screws do i have to get
3.my comp model is Compaq SR1730IL
4.what wires should i attach then
Old 21-07-2007, 10:00 PM   #4 (permalink)
slugger's Avatar
d screws nothin special just ask 4 screws 2 attach d hdd into d cabinet.
d packet of screws not cost more than 10 bucks
or if u got small screws, try usin them, c if it fixes d hdd 2 d cabinet frame, den u wudn't have 2 buy d packet of screws
as 4 cable, since it is a SATA drive ask 4 SATA cable, d dealer wud know
slugger is offline
Old 21-07-2007, 10:28 PM   #5 (permalink)
The Unknown's Avatar
See this image captured by me:
Guess now how to fix ur HDD. Just connect the cables present inside ur cabinet. The colored connecter is the power supply. The data cable is not visible in the image. You can see the screws, where they're fixed.
KDE on ArchLinux
The Unknown is offline
Old 23-07-2007, 12:27 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
@The Unknown ...... u have the pix ...... nice kinda tut ........
u can also checkout some old digit mags ........ where u can find out abt all connections 2 hdd, motherboard, ram, rom etc ........
i cant recollect the issue ......... just ask the mods or digit ppl ........ nice explanation with pix ........
... W H O T ...
ax3 is offline
Old 23-07-2007, 09:14 PM   #7 (permalink)
Thanks budduy!! I had captured it from our all in one handycam.
KDE on ArchLinux
Why hard disk drive as removable drive? Sheik Rasheed K Hardware Q&A 6 25-03-2007 10:01 AM
Seagate 160gb Hard Drive installation woes sysfilez Hardware Q&A 4 26-09-2006 11:12 AM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
Hard Drive toooo hard for 815 Sonu Yadav QnA (read only) 20 16-06-2005 03:55 PM
Hard Drive! Optical or Magnetic Based Drive Stitch QnA (read only) 1 30-05-2005 11:14 PM
- by Piyush
