Old 02-03-2005, 08:53 PM   #1 (permalink)
Default could u tel me?how?
How can i change logo of "windows" which is displaying "mycomputer-->properties. n right hand side top panel logo. not down one. down one can do. but i want to change just uper one. ur any ideas r welocome.
Hey I am cool..........
kamaal is offline
Old 11-03-2005, 12:18 AM   #2 (permalink)
Default about logo
Use resource hacker
download it from net.
ganesh_dabhade is offline
Old 11-03-2005, 01:53 AM   #3 (permalink)
hafees's Avatar
Yes! download resource hacker from
http://www.users.on.net/johnson/resourcehacker/
hafees is offline
Old 11-03-2005, 02:14 AM   #4 (permalink)
1) Search (Windows folder) & Modify this file "sysdm.cpl" with exescope or Resource hacker I use Resource Hacker
2) Replace the two bitmaps u see in Resource hacker with ur own bitmaps. Create two bitmaps one 256 color and the other 16 color and then replace.
Save the changes.
3) After modifying backup the old file and replace with the modified file in these two folders since it is a protected file. Order is significant !
X:\WINDOWS\SYSTEM32\dllcache
X:\WINDOWS\SYSTEM32
neerajvohra is offline
- by Piyush
