Hey Guys , Got myself a Seagate 250GB SATA HDD today , now I have a total of 3 HDD's , The other two are 80GB and 120 GB , both SATA. so a total of 450GB on paper ( actual space will obviously be less )
Now my primary HDD is the 80GB one. I have XP installed here taking 12 GB . 4 more partitions take up the rest of the space.
120 GB one is where I have installed Ubuntu Feiste.
25+ GB for root partition and 950+ for swap . Rest of the space is divided into 3 partitions.
Now I have added the new drive and want to use it as the primary HDD i.e., I want XP to be installed there set it as C drive and also want to install Vista on this drive.
I want 120 GB drive for only storing Media files ( videos and stuff )
I want to use the 80GB drive only for Linux.
Now how can I reconfigure the drive and make my system boot from the new drive. Removing the 80 GB drive , installing XP and then reconnecting it to copy the data... Will that work?
I got another problem , When I try to create a new partition in the new drive , the partition gets created but the rest of the unallocated space still shows 230GB+ of space available. Even if I create multiple partitions the result is the same. I have attached the screen shot.
Waiting for reply
EDIT: There was no problem with the new drive partition. I was allocating space in MB's insted of GB
