Old 02-03-2005, 08:46 PM   #1 (permalink)
rachitboom2's Avatar
Default 8X on PCI-x or PCI-X on 8X ????
Just two simple questions =>
Q 1. Will an AGP 8X G-card work on an PCI-X mobo ( If not, WHY?)
Q 2. Will an PCI-X G-card work on an AGP 8X mobo ( If not, WHY?)
PS. I know that I have asked one of the questions before also but nobody properly answered !!!
Laptop: HP DV6 - 6017TX: Intel Core i7 + 4GB DDR3 + ATI HD6770
Cell Phone: NEW Samsung Galaxy S2 i9100 16GB
Consoles: 3x Xbox 360 Slim 250GB Gamertag: Rachitmayhem
3x PS3 320GB Slim Gamertag: Rachitmayhem
mahule_rachit@yahoo.com
rachitboom2 is offline
Old 03-03-2005, 02:18 AM   #2 (permalink)
dOm1naTOr's Avatar
Neither an AGP card fits in a PCIE slot, nor a PCIE card fits in an AGP slot.
Thats their interfaces (pin) are different.
Don't be upset , an AGP card loses out to a PCIE of the same chipsets by inches.[/b]
dOm1naTOr is offline
Old 03-03-2005, 02:23 AM   #3 (permalink)
No actually you dont understand my problem actually I was upgrading so I thaught why no use my old 5700 pro on my new system.
Old 03-03-2005, 02:34 AM   #4 (permalink)
dOm1naTOr's Avatar
Sorry, you cannot install your 5700 AGP card on a system based on the following chitsets:
Intel 915 for P4 5**
Intel 925 for P4 5**
nforce4 for AMD Athlon64.
(AMD Athlon 64 can also be used on mobo with nforce3 chipset which has AGP slot)
Inorder to use your older card in your new system go for 865 or 875 chipset based mobo for intel.
Go for nforce3 if you prefer AMD 64
Go for nforce2 or 3 if you prefer AMD Semprons.
Old 03-03-2005, 02:36 AM   #5 (permalink)
Well thanks aravind_n20 for your Information.
Old 03-03-2005, 07:07 AM   #6 (permalink)
ohhhh noooo one more thread from u regarding AGP nd PCI???????
i think i told u clearly in ur previous thread too that u cant mix either of them,icecoolz also told u the same...... was there a need for a new thread....
grinning_devil is offline
- by Piyush
