Old 19-07-2007, 09:04 PM   #1 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
Default Comp doesnt shutdown!!!
hi guys....im posting after a long time.....
my comp has dedveloped a problem after a power surge..wen in windows i say shutdown it logs off then it restarts....it doesnt stop..wat can b the problem?
Without sorrows happiness would be boring!
romeo_8693 is offline
Old 23-07-2007, 10:52 PM   #2 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
Default Re: Comp doesnt shutdown!!!
kmon guys...
Old 23-07-2007, 11:54 PM   #3 (permalink)
slugger's Avatar
r u runnin win2k3? i 2 face dis prob sumtime [no particular frquency]
wonder y?
i dont tihkn its got anytihn 2 do wit d surge 'cause i got a spike guard
slugger is offline
Old 23-07-2007, 11:56 PM   #4 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
try these different methods , they may help..
4 Tricks to Shut Down your Windows
n00b forever...
~Phenom~ is offline
Old 24-07-2007, 11:03 PM   #5 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
@slugger:nope win xp...,no spike guard but ups is there.....
@phenom:it does all the routines for shutdown but instead of totaly going off it restarts.....
it is as if the comp is made to shut down but with the power-on switch shorted....(tho it is not shorted...)
Old 24-07-2007, 11:43 PM   #6 (permalink)
Try disabling 'Auto restart' feature and note any error message displayed during shutdown.
My Computer > Properties > Advanced tab. Under “Startup & Recovery,” click Settings. Under “System Failure,” uncheck the box in front of “Automatically restart.”
sashijoseph is offline
Old 25-07-2007, 12:06 AM   #7 (permalink)
slugger's Avatar
never enabled it, still d comp restarts but in no particular freq
slugger is offline
Old 25-07-2007, 12:08 AM   #8 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
@romeo
Also try to update the VGA drivers.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 25-07-2007, 12:12 AM   #9 (permalink)
slugger's Avatar
Originally Posted by Vishal Gupta
@romeo
VGA drivers r 4 grafix cards na?
aaaaa dat cud b d reason 4 restart, 'cause my NVIDIA drivers r 2-2.5 yrs old. d newer NVIDIA drivers don't get installed
but y only infrequent restarts and not all d time
slugger is offline
Old 28-07-2007, 06:27 PM   #10 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
@vishal....dude the screen after a boot is fine only for few secs then it fades and all waves like flow across the screen....and how r not-being-able-to-shutdown and vga drivers connected?
@sashijoseph:they all r proper....
Old 28-07-2007, 07:20 PM   #11 (permalink)
that happens when electricity supply is erratic (combined with your monitor's refresh rate) or there is an electromagnetic interference. As for your restart, you can run antivirus to check your system files. Also, check your mobo battery (small one) & your psu - one of these may be the culprit.
"Right Off the Assembly Line" --> Time to Seek & Destroy :lol: :D
abhra is offline
Old 28-07-2007, 07:56 PM   #12 (permalink)
Microsoft MVP
I was just trying to help u. If u don't want it, then its OK.
I suggested to update VGA drivers coz I hv observed most of the times that such power related problems are caused by faulty or old VGA drivers.
Old 29-07-2007, 06:33 PM   #13 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
@vishal...ur taking me wrong dude...i was giving more info to u....may b d sentence formation was nt right..bt i dint mean to b rude.....and abt vga i just wanted to know d reason....pls no hard feelings
can it b bcos of heatin of display controller???
Old 29-07-2007, 06:40 PM   #14 (permalink)
Microsoft MVP
No problem buddy. Its OK.
Actually as I earlier said, if ur VGA drivers are not updated then sometimes u can face such strange problems. So try to update the drivers.
Old 29-07-2007, 07:16 PM   #15 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
thanx dude...i tried update vga driver but it dint work....
Old 29-07-2007, 07:27 PM   #16 (permalink)
Microsoft MVP
Also try to reset ur BIOS settings and then make sure that power settings are set to ATX there.
Old 02-08-2007, 09:06 PM   #17 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
hoe to reset the bios?
Old 02-08-2007, 09:42 PM   #18 (permalink)
slugger's Avatar
usually removing d CMOS battery 4 around 10 mins duz d job.
in d BIOS der is also an option 4 loading fail safe defaults, u may want 2 try dat. but i seriously doubt dat it wud solve d problem, cause 'earlier [and even now] i used 2 format d hdd and reinstall d OS every other day, so had 2 reset d bios [4 sum reason my install stalls in middle wit my customised bios settings], but even wit fail-safe defults, my comp restarted
did u try installin all d win patches dat auto update throws @ u, 'cause i just noticed dat ever since i patched my OS d reinstall issue seems 2 have disasapeared [it is ne way so infrequent dat it doesn't really bother me]
Try keepin ur OS up2date with all updates installed and c if it helps
slugger is offline
Old 02-08-2007, 09:43 PM   #19 (permalink)
Is actually a real word..
actually this sounds like the sassar virus, you boot the computer then it shuts down correct?
“They put me here because I’m from Canada and they think I’m slow, eh?..."
Liggy is offline
Old 02-08-2007, 09:44 PM   #20 (permalink)
slugger's Avatar
d problem seems 2 b just d opposite, d comp just does not shut down
slugger is offline
Old 03-08-2007, 07:21 PM   #21 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
@slugger..may be bcos of the updates cos this comp is nt updated.....
Old 03-08-2007, 07:28 PM   #22 (permalink)
slugger's Avatar
try keepin ur OS up2da8 and c wat happens
my restarts are extremely rare, but they happen
actually i jumped the gun yesterday when i said that my comp not restarting anymore
but 1 thin i am sure of is that, it is OS-related, because in the middle i had re-installed Win200 and used it for a couple of months, not 1 restart
but then i reinstall win2003 and it occurs again
did you also try vishals VGA update solution, bcos right now the NVIDIA drivers that i use are around 3-4 yrs old, thenew drivers dont support my card.
try updating ur grafix card drivers also and c waht happens?
slugger is offline
Old 03-08-2007, 08:16 PM   #23 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
grafix is on board..tried the latest drivers possible..nt working.....
H'to conekt Off Comp with Home Comp abhijitroy QnA (read only) 2 22-01-2007 10:53 PM
Windows SHUTDOWN Problem, system freezez on shutdown screen catch_maxi Software Q&A 2 16-03-2006 07:38 PM
"improper shutdown" msg on proper shutdown mvishnu QnA (read only) 2 26-02-2006 06:50 PM
services doesnt stop when shutdown! legolas QnA (read only) 5 13-12-2005 04:57 PM
Windows Update doesnt Support FireFox sify doesnt digit foru Choto Cheeta Software Q&A 6 11-02-2005 03:45 PM
- by Piyush
