LinkBack (1) Thread Tools Search this Thread Display Modes
Old 19-07-2007, 07:07 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Always Questioning?
emailaatif786's Avatar
Red face Is it DVD-R or DVD-RW?
I bought a DVD MoserBaer 8.5 GB Double Layer.
It has written:
MB 8X DVD+R 9 DL/SS/8.5 GB/420min.
At the bottom it has also written in Black RW DVD+R DL
Now, Is it a Once write or RW ?
:smile: Love Digit
emailaatif786 is offline
Old 19-07-2007, 09:12 PM   #2 (permalink)
Is actually a real word..
Default Re: Is it DVD-R or DVD-RW?
rw
“They put me here because I’m from Canada and they think I’m slow, eh?..."
Liggy is offline
Old 20-07-2007, 02:55 PM   #3 (permalink)
Always Questioning?
Wink Re: Is it DVD-R or DVD-RW?
Originally Posted by Liggy
RW
Are you Sure?
Telling you that it costs Rs 140.
THAT Should'nt go in Vain!
:smile: Love Digit
Old 20-07-2007, 06:07 PM   #4 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Are you Sure?
It is a DVD+R i guess. I buy Reno-tech for Rs 15 and it has same DVD+R written on side and RW written below. I guess they have one DVD Label Printer
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 21-07-2007, 11:24 AM   #5 (permalink)
Always Questioning?
Cool Re: Is it DVD-R or DVD-RW?
Yeh, I have that RW also written on LG DVDWriter.
They write +R, -R, and then at bottom RW? Are they MAD?
What is +R and -R?
And tell me now, is that DVD RW?
:smile: Love Digit
Old 21-07-2007, 10:22 PM   #6 (permalink)
CA50's Avatar
+R and -R are two different formats of DVD. They are not compitable with all
DVD writters.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 22-07-2007, 02:52 AM   #7 (permalink)
R
tharkiman is offline
Old 22-07-2007, 07:13 AM   #8 (permalink)
well buy a rw disk and try to butn on that then try again it itdoesn't work then obviously I'm wrong.
Liggy is offline
Old 22-07-2007, 11:24 AM   #9 (permalink)
Always Questioning?
I actually want to burn Fedora 7 on it. First I will burn 1Kb file on it, keeping it MULTI SESSION DVD. Then I will burn Fedora 7 on it, but will then Fedora Burn successfully? Will it BOOT on "Continued MULTI SESSION DVD"?
:smile: Love Digit
Old 22-07-2007, 11:32 AM   #10 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Well very few DVD writers support dual layer Rewritable DVDs so if ur DVD writer which surely does not support dual layer Rewritable DVDs reads these DVDs then its DVD +R DL only.And i have confirmed it as i myself got into the same problem when i bought 5 Dual Layer Verbatim DVDs from here at digit bazaar.
Harvik780 is offline
Old 22-07-2007, 07:33 PM   #11 (permalink)
Thumbs up Re: Is it DVD-R or DVD-RW?
Why don't you just check with Nero Infotool. will give complete detail with compatible writing speeds and all other info.
And that's the simplest way to be sure...
dabster is offline
Old 22-07-2007, 08:01 PM   #12 (permalink)
It has written:
wat was the price like ?
palito is offline
Old 26-07-2007, 02:11 PM   #13 (permalink)
Always Questioning?
Unhappy Re: Is it DVD-R or DVD-RW?
Rs 140
On DVD outer Plastic Case, it is written 8GB DL +R
But on DVD, it is written RW.
Nero info Tool cannot give details on it!
:smile: Love Digit
Last edited by emailaatif786; 26-07-2007 at 02:11 PM. Reason: Automerged Doublepost
Old 26-07-2007, 05:40 PM   #14 (permalink)
Rs 140
Can't see any reasons that why you unable to check the media type by Nero Infotool, seems that you bought some special kind of disk which nobody can make out, what it is ...?
Whatever...,, see the Image. iT clearly tells that it is a single layer DVD+R Media.
dabster is offline
Old 26-07-2007, 06:07 PM   #15 (permalink)
Always Questioning?
But, you are finding info of a 4 GB DVD, but I am telling of 8 GB DVD.
Insert fresh(UNWRITE'ble n moserbaer) 8GB DVD in drive, and use Nero InfoTool, and take n Post Screenshot all the results!
:smile: Love Digit
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/63382-dvd-r-dvd-rw.html
Thread My DVD - RW drive not recognizing Digit DVD's | Digit Forum | BoardReader This thread Refback 08-07-2011 09:45 PM
- by Krow
