Verify that
Wininet.dll is in the
C:\WINNT\SYSTEM32 directory. If the file is missing, click Start, Search, and For Files Or Folders to try to locate it. If you find more than one copy of the file, check the version information for each file (you can find this information by right-clicking the file, selecting Properties, and selecting the Version tab). Copy the most recent version to the
If Wininet.dll is already in the C:\WINNT\SYSTEM32 directory, it may be an older version associated with a third-party application, thereby causing compatibility problems. Search for a more recent version of the file to use as a replacement.
If you don’t find Wininet.dll, Go Here->
http://www.dll-files.com/dllindex/dl....shtml?wininet
If still the problem persists,then update ur IE to latest version
