Old 02-03-2005, 01:51 PM   #1 (permalink)
Default cant update pc-cillin 2005..
hello ppl,
i am using trend micro pc cillin internet security 2005 from yesterday and i am not able to update my virus definations..it says incorrect server response..what could be the problem?
i had the same problem with nod32 and nav 2005 too . can someone tell me what could the problem be..could it be my isp is blocking it cuz my zap is allowing all of them.
thegame_rulez is offline
Old 02-03-2005, 01:59 PM   #2 (permalink)
u have the original key / serial number for pc cillin ?
try diabling firewall . even pc cilling's firewall just to check if ur able to update . anyways i would suggest using a download manager , just in case the connection breaks during update . Hope u have updated the scan engine too , as there seems to have been a problem with older ones
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 02-03-2005, 02:14 PM   #3 (permalink)
yes..i have the original key. btw can i get the definations in an exe format just like nav defination files..which would be much easier?
Old 02-03-2005, 02:46 PM   #4 (permalink)
u can download the lpt### (#=update number) from here . its in zip format and its advicable to download using a download manager or opera's or firefox's d/l manager as they have resume too . if u have the original key , contact cillin's tech support in india regarding auto update . did u d/l the scanengine too and update it ?
trendmicro.com/download/pattern.asp
klinux is offline
- by Krow
