Old 02-03-2005, 12:36 AM   #1 (permalink)
gxsaurav
Posts: n/a
Default 64-Bit Coming to a Celeron near U
Intel has clearly stated that they will be releasing their AMD-64 compatible technology called EMT64 (by intel) to their budget CPU segment
http://www.theregister.co.uk/2005/03...64bit_celeron/
Looks like Intel & MS are all set to make 64 bit computing for all
Here is a review of the new Intel 6xx series CPU with EMT64
http://www.tweaknews.net/reviews/intel64/
Old 02-03-2005, 02:44 AM   #2 (permalink)
i want to know that pentoum 4 is latest when pentium 5 is coming
what is the current latest like 3.2 Ghz or what
AMIT AGARWAL
AMITAGARWAL02 is offline
Old 02-03-2005, 03:05 AM   #3 (permalink)
swatkat's Avatar
LGA 775:-
3.8 GHz Exreme Edition
3.6 GHz with HT
478 pin:-
3.4 GHz with HT
2.8 GHZ non HT
http://swatrant.blogspot.com/
swatkat is offline
Old 02-03-2005, 11:41 AM   #4 (permalink)
hey swatkat,wats the diff btw socket 775 and 478..tel me in terms of performance etc..
krisjr is offline
Old 02-03-2005, 01:40 PM   #5 (permalink)
gxsaurav
Posts: n/a
The Pentium 5 will not come again for a long time, intel has ditched the Pentium 4 name & their next Dual core CPU, on the Intel 945 & 955 chipsets will be caleed Pentium D xxx, where XXX denotes the CPU number (660, 880 etc)
Socket 478 is for the old Pentium 4 northwood & some Prescotts, found in Intel 845, 850, 865 & 875 Chipsets
Socket 775/T is the new Intel socket for a long time, as it provides a good upgrade path, from Intel, for the Intel 915/925 chipsets,
it's just the socket & doesn't gives any performance difference
Old 02-03-2005, 11:43 PM   #6 (permalink)
 Macboy
goobimama's Avatar
I don't think pentium 5 would ever be a name, because Pente itself means 5. After the 486, instead of giving it a name 586, they renamed it Pentium. Now if they have a pentium 5, it would be quite....not right. am I right?
I'm like a bird... :)
goobimama is offline
- by Krow
