16-07-2007, 12:50 PM
Which is a fastest DVD to DivX converter?
Which is the fastest DVD to DivX converter available in the market?
I have heard of Imtoo and DivX converter..
Kumarpal Shah
16-07-2007, 12:53 PM
Host4Cheap.org
Re: Which is a fastest DVD to DivX converter?
Software wont dpend much. Quality of Movie you want and Processing speed would make the major differnce
http://www.host4cheap.org/
16-07-2007, 10:08 PM
Case Mod - 60% ||||||----
Core2Duo!
16-07-2007, 10:14 PM
y not a quad core processor?
16-07-2007, 10:17 PM
ANGEL OF DEATH
use this converter Ultra Quicktime Converter.i have convert .VOB(1 GB) to .AVI (576 MB)
| Dell 15z + WD 2TB | | Dell Studio 1555 + WD 1TB | | iPhone 4 32 GB | | Samsung Galaxy S2 White | | Good Desktop Power Of C2D + 4850 |
17-07-2007, 01:23 AM
Rebooting
AutoGK works fine for me...
4GB VOB to 700 MB DivX or Xvid around between 45mins to 1hours and 10min
Dont know why the Rate vairs that much
rebooting
ChotoCheeta.com
17-07-2007, 08:49 AM
That is pretty fast, what CPU-RAM combo you are using.AutoGK takes more than 2 hrs for me....
tried Nero recode and it works at 90-97fps thus less than 40 minutes.I just Wonder what is the problem with AutoGK on My system. What stats you get for Nero Recode then...
I think that makes difference, Because you need optimized codecs and software for the hardware, e.g software should support MMX,3DNow,SSE,SSE2,and SSE3 optimizations(I haven't seen any with SSE3)
Reason: Automerged Doublepost
17-07-2007, 09:18 AM
Rebooting
Tried with C2D E6600 @ 2.8 !!! with 4GB DDR-II 667 MHz !!!
P4 630 with 1 GB DDR-II Dual Channel 533 MHz takes over 6 to 8 hours
Nero takes 20 mins (+ -) !!! for 4 gb DVD to Single CD !!!
quality is not good infact no where compare with AutoGK... !!
rebooting
ChotoCheeta.com
17-07-2007, 11:01 AM
Host4Cheap.org
I didnt say software doesnt make difference. I said....it wont make much differnce. Processor has the real power
17-07-2007, 12:27 PM
The Devil
So which one is the best?
17-07-2007, 05:31 PM
AutoGK is a good Utility plus its completely free, But I don't like it much due to its speed(Needs high end hardware), other software like Nero Recode Perform very fast but output is MP4, there are mp4 compatible players now in the market.
I use Dix Converter 6.0, due to its speed on same hardware... But it doesn't give any configuration control on quality.
me still looking for better options.
17-07-2007, 08:48 PM
Back to l33ching :)
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
^^u get mp4 compatible players here? can ya gimme sum models?
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
17-07-2007, 11:09 PM
The Devil
I use DivX DVD Ripper. Don't know whether that's any good or bad than the others.
17-07-2007, 11:36 PM
Google Bot
autogk and total vc here
18-07-2007, 01:15 AM
* Teh Flirt King *
AutoGK. I dont exactly remember who recommended it to me, but I think it was Cheeta Bhai.
Don't ask about time though. It takes a lot of time in my 2.0Ghz p4.
18-07-2007, 09:22 AM
Host4Cheap.org
Maybe, anyone here can ask aXXo on Demonoid on what he uses
18-07-2007, 05:14 PM
recently saw a DVD player model of LG@ezone and that had mp4 compatibility....
19-07-2007, 03:24 PM
Try TMPGEnc XPress 4.3.1.222 its rally good.....and one of the best...
19-07-2007, 05:30 PM
#19 (permalink)
Rebooting
as far quality goes I think I would stick to AutoGK... keeps a great quality
rebooting
ChotoCheeta.com
19-07-2007, 05:55 PM
#20 (permalink)
aka. ViKiD? <^_^>
Hey why dont u try SIMPLEDIVX...its quite kool
Wadadadada!! ??
19-07-2007, 06:01 PM
#21 (permalink)
Use AutoGK and choose xviD as a codec...the result will be great.
BTW, as far as AGK home site info, it is not optimized to take benifit of a dual core processor, so do not expect a high speed if you do not have at least 1GB of RAM. Only Dr DivX is optimized to use the full benifit od a C2D proccy but it is horribly buggy , crash prone though it is free.
Conclision: Use AGK and as much as RAM as possible.
For Pictorials, Tutorials and software reviews visit: www.sroyc.blogspot.com
19-07-2007, 08:30 PM
#22 (permalink)
Rebooting
Even AutoGK faces problem with x86 windows and more than 3GB RAM... !!!
I needed to use PAE and 3GB Switch to make sure AutoGK Can use the full ram, even though tons of it stays un-used
rebooting
ChotoCheeta.com
21-07-2007, 04:43 PM
#23 (permalink)
I am not really sure Choto Cheeta whether you shall be able to achive what you intend to, but still I do not think that you can make it work any faster beyond a limit irrespective of the amount of resources you throw at it...I think it [or any other sw] is not optimized to do that.
Well I am not very knowledgeable on this ground of tweaking, but I can vouch for AGK and XviD when it comes to Video Conversion quality.
Best of luck
21-07-2007, 08:03 PM
#24 (permalink)
Rebooting
Hey, I am not opposing AutoGK...  even I too Vote for it as to me the best utility...
What I said, is with the RAM ammount statement, as u wrote,
Therefore I just commented that I tried to do so, the Results are like this,
AutoGK with 2.4 GHz E6600 and 2 GB DDR-II 667 does a job within 45 to 55mins,
AutoGM while playing NFS MW with 2.4 GHz E6600 and 2 GB DDR-II 667 does the same job within 45 to 55mins,
AutoGM with 3.2 GHz E6600 and 4 GB DDR-II @ 750 MHz does the same job within 45 to 55mins,
AutoGM while playing NFS MW with 3.2 GHz E6600 and 4 GB DDR-II @ 750 MHz does the same job within 45 to 55mins,
The job was Casino Royal 4.7 GB DVD to 700 MB xvid
so, there is not much difference even change of Speed and amount of RAM in system !!  and played NFS to see if it delays the proces or not....
But I just cant figure it out, why the same job with same settings takes some time 45mins and some time as high as 55mins... I run the encode atleast now 25 times  Just Windows XP SP2 DX 9.0c and Drivers !!!
rebooting
ChotoCheeta.com
21-07-2007, 08:33 PM
#25 (permalink)
I guess PAE is enabled by default in XP SP2 for AMD64/EM64T ain't it....?
As your results show, that AutoGK is not using the complete hardware resources, that are available. But I guess 45-55 min is pretty good for superb quality xvid movie.
But keeping with the thread's motto(Best sw utility and not hw thing) can anyone suggest a fast converting software similar to Nero Recode 2(optimized for newer CPU) But output should be a XVID-avi. Don't like mp4 quality of Nero Recode, besides it is not compatible on many players...
Search this Thread |
