Hello guys,
My Sony Vaio Laptop doesn't hibernate when I click "hibernate" from Start menu and also when I close lid of the laptop.
It had been successfully hibernated since the purchase of the system.
I checked the power options and all the settings are there unchanged, especially the option "enable hibernation" etc.
this problem was found since last night.
I tried with system error check, nothing found wrong, scanned thoroughly for spyware using "ad-aware 2007", "spybot search and destroy " some minor spywares were there and I removed it, then Performed a thorough full scan with Avast home edition, found also some viruses and removed.
eventhough the problem is still there.
I had installed Nokia PC Suite 6.84 last night and it was ended in failure and re-installed the pc suite once again, so I thought it was the hibernation problem with the installation of pc suite, hence I removed the same, still problem persists.
I use my laptop for the presentation purpose and the hibernation option is very useful to me.
could you please give me a soln to this problem without a system restore option???
