Old 15-07-2007, 03:49 PM   #1 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
Default Cant open drive with double click
recently i found a virus in my memoery card and it associated with te say autorun.inf file so i deleted it .. now whenever i try to open the memory card its asking to which program it has to open.. doesnt open the folders..
but yesterday similarly i found the same virus some salxx.exe(think so)so i deleted them ... but now whenever i try to double click on my hard drives like d: e: it opens "open with " option and shows all the programs...
wht shal;l i do.. how to again make it default to open folders on double click ..please help
solved the problem myself...
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
Last edited by naveen_reloaded; 15-07-2007 at 03:49 PM. Reason: Automerged Doublepost
naveen_reloaded is offline
Old 16-07-2007, 01:21 AM   #2 (permalink)
Default Re: Cant open drive with double click
Hey my friend too had the same prob. Then avast was not able to detect the virus but now "avast detects it"(i recomend install & update avast and do a full system scan),
any way there is the way i removed it manually.The virus exists in 3 files
1)sal.*.Exe
2&3)ms*80.Exe
don't remember exact names but in task maneger end tasks with such names,
search and delete those files(check show all files if no result found),
in msconfig uncheck those files.
And let me know.
busted is offline
Old 16-07-2007, 08:58 AM   #3 (permalink)
Geekologist
piyushp_20's Avatar
hey buddy,
i m also getting the same prob,
whenever i restart my pc then i get the error message saying "windows cannot find the file c:\windows\lsass.exe, please check the path"
now what should i do.
AVG internet security with latest updates detected no virus in it.
Piyush
piyushp_20 is offline
Old 16-07-2007, 10:17 AM   #4 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Originally Posted by piyushp_20
hey buddy,
lsass.exe
is a system file. its not a virus. Still there are trojans with same name. Try checking it with your Antivirus, fully updated.
If it founds nothing dont worry, its not a virus then.
Quiz_Master is offline
Old 16-07-2007, 11:40 AM   #5 (permalink)
Geekologist
piyushp_20's Avatar
thanx buddy, i was really confused coz i had seen a trojan with the same name.
Piyush
Old 16-07-2007, 10:46 PM   #6 (permalink)
yeha so you should remove the startup entry from
stert->run
type "msconfig" and go to startup folder and uncheck the lass.exe file
busted is offline
Old 17-07-2007, 08:48 AM   #7 (permalink)
Geekologist
piyushp_20's Avatar
ya done that already when u told that it was a system file. nw the problem is solved.
newaz thanx buddy.
Piyush
cant open my drives by double click ayush rathi Software Q&A 21 07-07-2007 09:00 AM
Can't Open any of my hard drive with double click jimmyondigit QnA (read only) 10 11-02-2007 05:09 PM
double click to open harshagarwal Software Q&A 2 27-01-2006 03:48 PM
cannot open with double click runtime error QnA (read only) 5 28-04-2005 01:22 AM
double click open search window Techmastro Software Q&A 5 28-03-2005 11:04 AM
- by Krow
