Originally Posted by jack_the_ripper
well i guess there's no use creating images coz the backups are going to be created on the drive itself.. shud invest in another hdd now i guess, instead of taking any chances with this one!
yup generally when a HDD makes clciking noises, Usually not a good thing. had a maxtor do that to me. How old is the western digy, if you pull it out there should be a sticker on there that states when the warrenty will expire, and if you're still in that warrenty take it back (should not matter if it came from the states or not)
