14-07-2007, 10:00 AM
The Devil's Advocate
1 ram better than 2???
is having 1 1gig ram modle better or having 2 512 ram modules better ... i chkd the net and came across a site which said 2 are better .... but how true is it and is there any noticable performance change ???
http://beingmanan.com
14-07-2007, 10:03 AM
Rebooting
Re: 1 ram better than 2???
In dual Channel mode offcource 2 are necessary !!!
rebooting
ChotoCheeta.com
14-07-2007, 10:04 AM
Alive Again...
1 is better in terms of money
it can save ur price instead of buying 2
also if u have 2 slots
& u put 1 1GB RAM
u can upgrade to 2GB in future
14-07-2007, 10:25 AM
Genius in making mistakes
512X2 is always better than 1X1gig stick coz performance of ur com gets divided on two separate sticks not on one. it ll boost ur entire com performance.
14-07-2007, 10:27 AM
Rebooting
Only if one runs it under Dual Channel mode...
if doesnt, then doesnt matter whether 2 or 1 Stick... performance will be same...
rebooting
ChotoCheeta.com
14-07-2007, 12:49 PM
how do u come to know tht dual channel mode is enabled?
14-07-2007, 01:01 PM
+point -point
The plus point:
Tasks are divided on separate RAMs
The minus point:
Consumes more power.
KDE on ArchLinux
14-07-2007, 01:08 PM
Gangsta
Location: I come from the land of WARRIORS, land of 5 rivers, where the alcohol will make your liver quiver!!
Yeah ! 2X512 Is Better than the single Igb ram in terms of its performance(not much better ) , but the question is still there that why would you like to pay a sum of money for this little better performance .
I must advice you to go for the 1gb all ,that will be better for you ,but still choice is yours !!!!!!!!!!
Almost Every one of my posts contains the word lol. I laughed out loud at everything, even when it's not funny. lol
14-07-2007, 01:09 PM
NP : Crysis
if ur mobo supports dual channel and both ram modules are isentical, using two modules is much better than one
14-07-2007, 02:26 PM
hmmm ... would it be fair if i concluded that 2 rams than 1 is advisable however there isnt any significant performance change
14-07-2007, 07:25 PM
NP : Crysis
^^u got the first bit correct that 2 ram modules are better than 1, but the performance diff is significant
14-07-2007, 07:54 PM
hmmm ok thanx every1
14-07-2007, 08:04 PM
yes 2 are better than
15-07-2007, 12:01 AM
Is actually a real word..
So if/when I install a real version of Vista it is advisable to have two sticks (2x512) as apposed to one. Also was told if I had four slots I should put ram in 1 & 3. not 1 & 2, does that make sense to anyone???
15-07-2007, 12:51 AM
ya theres some theory behind it ... some parallel access to the ram which is better
15-07-2007, 12:57 AM
You gave been GXified
Its simple dual channel. Buy 2X512 MB sticks instead of 1 1 GB is better due to Dual channel memory support in all CPU platforms out there right now. Nothing more to discuss.
Yup 1 & 3, then 2 & 4, thats how dual channel arrangement works.
about.me/gxsaurav
Security freak
Location: 01100001 01110100 00100000 01101000 01101111 01101101 01100101 00100001
While what these guys are telling you is true to a great extent, this also depends on your motherboard. I have a very strange motherboard (that doesn't seem to follow convention) that has dual channel ability (the manual has like 2 pages of RAM configuration options...if you use 1/3 or 2/4 then it's single channel, 1/2 or 3/4 is dual channel, etc...). So make sure you check with your motherboard manufacturer to get the optimum setup (just in case).
Linux Admin by profession. OpenBSD user by choice.
15-07-2007, 07:34 AM
#19 (permalink)
thanks guyz, yeah I did check out my OEM's spec before I tried it, was just woundering if it was fact or fiction, Thanks everyone!
15-07-2007, 09:37 AM
#20 (permalink)
HELP AND SUPPORT
Yes,I experienced a Bootup Error due to this on my Intel MotherBoard
15-07-2007, 05:22 PM
#21 (permalink)
Cool as a CUCUMBAR ! ! !
2 RAM modules are better than 1 ..........
... W H O T ...
Search this Thread |
