Old 13-07-2007, 10:38 PM   #1 (permalink)
Default CD-Rom drives not detected
I have two drives Lite-on Combo drive and Lite-on Allwrite DVD writer. Now my drives are not deteced at BIOS and in windows as well..
I have tried reconnecting the cables and check for lose connections. I have also interchanged the cable by just connecting the combo drive. I have used Add hardware wizard.....
PLs PLS help me if anyone can/knows it...Thanks a lot for taking notice....
Abhishek Bhattacharya
abhishek_del is offline
Old 13-07-2007, 10:43 PM   #2 (permalink)
bajaj151's Avatar
Default Re: CD-Rom drives not detected
try new ID cable.....may b ...cable is culprit.......
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is offline
Old 13-07-2007, 10:50 PM   #3 (permalink)
The Unknown's Avatar
Press Del key (Enter BIOS)=>select the 1st option (don't remember its name. NOTE: I am telling according to Award BIOS 6.0 )=> There will be something called detect HDD. Press enter on each of them and then try detecting the drives.
@bajaj, how 2 cables at the same time can be the culprit?
KDE on ArchLinux
The Unknown is offline
Old 13-07-2007, 11:07 PM   #4 (permalink)
bajaj151's Avatar
@ unknown
May b...i m wrong.....or....rite....
i just want him to check with new cable.......?
As...u too cant say surely...that....cables are not faulty....
bajaj151 is offline
Old 13-07-2007, 11:12 PM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
as unknown says check if the detection is disabled in bios.
one more thing can be that both the drives are set to slave or master and are on the same ide channel. set one as master and the other as slave and connect them to the same ide channel. (the change is done by jumpers at the back of the drive. refer manual for correct jumper position for setting drives as master/slave).
infra_red_dude is offline
Old 14-07-2007, 12:22 AM   #6 (permalink)
clmlbx's Avatar
try changing the ide slots . might it be a culprit
or try connecting this drives to other pc ( ur friend or someone else ) .
drives can also be a problem
clmlbx is offline
Old 14-07-2007, 12:37 AM   #7 (permalink)
Wire muncher!
Originally Posted by clmlbx
try changing the ide slots.
ide slots?!!!!
Old 14-07-2007, 12:41 AM   #8 (permalink)
left this forum longback
praka123's Avatar
I think it has something to do with power supply cables.else the channel set via jumper in back of the drive(s).
praka123 is offline
Old 14-07-2007, 05:14 PM   #9 (permalink)
The jumpers are correctly connected..i will try with a new cable and I am using American Megatrends....there is no option like detect hdd or something similar
Old 14-07-2007, 05:50 PM   #10 (permalink)
Beware of the innocent
ilugd's Avatar
step by step would be to
1. check if drives work in a friends computer
2. If ok, check if it is not a clash due to slave master setup- jumper settings
2. is power properly connected to the drives
3. The slot where the ide cable connects might be faulty. Try connecting an ide hard drive or another cd drive with a completely new cable in that place.
That should helpfully isolate the problem.
In BIOS there will be some setting to automatically detect connect devices. Try to redetect manually. And can you post your motherboard model ?
Life is too short. Have fun.
ilugd is offline
Old 14-07-2007, 10:04 PM   #11 (permalink)
clmlbx's Avatar
Smile Re: CD-Rom drives not detected
Originally Posted by infra_red_dude
ide slots?!!!!
I MEAN . THERE ARE TWO AVAILABLE IDE SLOTS ON BOARD . MIGHT ONE THAT IT IS CONNECTED TO IS FAULTY .
TRY CONNECTING TO OTHER IDE SLOT
clmlbx is offline
Old 14-07-2007, 11:53 PM   #12 (permalink)
Is actually a real word..
try resetting BIOS back to default settings. which screen looks more like the BIOS u have?
if it looks like this you want advance BIOS features there should be an option in there for you to select drives, the drives are IDE and not USB correct?!
Liggy is offline
Old 14-07-2007, 11:59 PM   #13 (permalink)
ilugd's Avatar
@liggy: are those camera snaps or is there a way to get screen shots of the bios?
ilugd is offline
Old 15-07-2007, 12:20 AM   #14 (permalink)
praka123's Avatar
oh,come on those are links from some uk forum eh?
praka123 is offline
Old 15-07-2007, 01:03 AM   #15 (permalink)
well these are snaps from hp website and other from some uk forum...Well the problem is solved..The new cable did it...but i would also like to know the bios thing...that detect thing
Thanks everyone for participating
One more question: In the jumper setiings there is one option: Cable select
What is it? (explain)
Old 15-07-2007, 07:42 AM   #16 (permalink)
actually I just did a gogle image search for BIOS screens. there are also BIOS simulators on the net which can walk you through basic setup of BIOS.
abhishek_del cable select allows the position of the drive on the cable to select whether the drive will act as master or slave (works for both optical and HDD, IDE drives). I was informed that it is better to manually put the jumper to either master or slave, and if you're still having problems accessing driver then put to cable select.
Liggy is offline
Old 15-07-2007, 10:52 AM   #17 (permalink)
ilugd's Avatar
oh, thanks. Nice to learn this. I never thought about that. Sorry for the offtopic query, but are there some simulators for routers and the like? Like Cisco router simulators for training in different models? Or should I create a new thread?
ilugd is offline
Old 15-07-2007, 12:12 PM   #18 (permalink)
ok so cable select means that it can act as master or slave and we can set master slave from the bios right?
However, I once changed one jumper from slave to cable select and it did not work...I mean funny characters were printed in the bios in First channel device... I think probably i should have made the similar changes to bios also.
Another question: In boot device priority down there is a Disk drives (+) option which we expand shows the two disk drives. Here, we can make one disk drive as one and other as two. This is not master slave, then what is it?
Thanks for the info guys
Old 15-07-2007, 12:35 PM   #19 (permalink)
Wire muncher!
this is the order in which the boot sector is searched on the disk. boot record is first searched on the disk that is marked 1st. if found then then i doesn't search further. if the boot record is not found here then it continues the search in the second drive.
Old 16-07-2007, 07:43 AM   #20 (permalink)
yeah dude create a new thread cuz I goggled mine and went through many pages to find it, can't remember where I found it a lot are just screen shot tutorials, you're better off askin the whole forum.
“They put me here because I’m from Canada and they think I’m slow, eh?..."
Liggy is offline
Old 16-07-2007, 05:32 PM   #21 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
try checking both of ur ROM drives on ur frds PC ........
else
try switching slots ......
else
bios update ....
else
change bios battery .......
... W H O T ...
ax3 is offline
Old 16-07-2007, 09:16 PM   #22 (permalink)
thanks but problem is solved
Old 16-07-2007, 09:20 PM   #23 (permalink)
"The Gentleman"
vish786's Avatar
hey dude how did u take pics of ur bios, they look clear ?? using some software ????
else
else
bios update ....
else
lol... u forget the printf(""); statement
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 16-07-2007, 11:26 PM   #24 (permalink)
the pics are from sources on the net..waise they look very clear and i don't suspect camera use, whoever got the original pics
Old 17-07-2007, 07:38 AM   #25 (permalink)
what do you guyz want the exact source? serious all I did was go to google images.
Liggy is offline
kernel-2.6.19 onwards CD/DVD IDE drives are detected as SCSI/SATA like /dev/scd0 freebird Open Source 13 13-04-2007 07:29 PM
HDD not detected sometimes pushkaraj Hardware Q&A 4 23-02-2007 08:07 PM
CD Drives not detected ..seems a little weird praka123 Open Source 11 11-08-2006 07:26 AM
HDD not detected rahul_becks23 Hardware Q&A 7 25-07-2006 09:37 PM
Digit's DVD drives the market's drives shakshy QnA (read only) 3 30-10-2004 09:27 PM
- by Krow
