Old 11-07-2007, 12:42 AM   #1 (permalink)
who cares...
vish1988's Avatar
Default T-sonic 610 or 630
i have decided to buy T-sonic ka mp3 player
but i am confused between 610 and 630
there no big prics diff between them
so please tell me should i go for 610 or 630
vish1988 is offline
Old 11-07-2007, 08:15 AM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: T-sonic 610 or 630
T 610
Nokia N86 8MP
Lucky_star is offline
Old 11-07-2007, 10:05 AM   #3 (permalink)
devilzdad's Avatar
T610??
i read dat sound quality in T630 is better than t610 and also economical but ofcourse some accessories are missing in 630 when compared to 610....
devilzdad is offline
Old 11-07-2007, 10:18 AM   #4 (permalink)
who cares...
vish1988's Avatar
Originally Posted by devilzdad
T610??
r u sure sound quality of 630 is better than 610??
vish1988 is offline
Old 11-07-2007, 10:25 AM   #5 (permalink)
Dreamweaver
Gigacore's Avatar
get T.610 it rocks. even i own it. now i upgraded its firmware to 3.4. having superb experience with it.
Gigacore is offline
Old 11-07-2007, 10:56 AM   #6 (permalink)
who cares...
vish1988's Avatar
while searching on google i got this review
http://www.techenclave.com/forums/t-...0-a-92067.html
if sound quality of 610 is better than 630 then i will go for 610
please reply soon
vish1988 is offline
Old 11-07-2007, 11:22 AM   #7 (permalink)
devilzdad's Avatar
I have not used 630...... i am also searching for gud pen drive with mp3 player with FM( check out my another thread) ........ its better if anyone who has used 630 gives his opinion....
Old 11-07-2007, 05:29 PM   #8 (permalink)
Pl explain how to upgrade the firmware and precautions to be taken if any.
Edit:
Done it with the help of instructions from transcendusa.com
V.Prem Kumar
janitha is offline
Old 11-07-2007, 08:21 PM   #9 (permalink)
Still Shining!
Lucky_star's Avatar
Not much difference in sound quality in 610 and 630. I found virtually, no difference in 610 and 630.
The only difference between 630 and 610 is that the 630 has got an external line-in port through which you can connect a microphone or an external sound input.
Additionally, it can play DRM files. 610 has got an internal microphone. And no need to worry about DRM music as long as you are in India.
Data transfer rates are same for 630 and 610. You cant expect it function exactly like a pendrive, because the data transfer speeds are awfully slow(30-40 seconds for a 5 MB file), but you can keep small files in it.
Combine it with a good quality earphone like the Creative EP-630 and you will get the best music.
The choice is yours.
Nokia N86 8MP
Old 11-07-2007, 11:56 PM   #10 (permalink)
a_k_s_h_a_y's Avatar
bundled earphones of 610 are better then 630
i suggest u get to get latest T.sonic 630 with Creatvie EP 630 Earphones
2 GB T.sonic 2.7k + Creative EP 630 900 Rs
total 3.5 approx....best deal best Combo...best music...best solution
the idea is get a EP 630 after 2 mnths if u cant immediately buy it...i mean collect money in 2 mnths time and go for it...i follow this rule always
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
Old 12-07-2007, 09:38 AM   #11 (permalink)
who cares...
vish1988's Avatar
thank you every one for there reply
yesterday i bought t-sonic 630 for Rs 2650/- from lamington
and sound quality is good
i have some quries about it
1:in the user manual for formware upgrade they have said that only
win98 and XP are supported but i am having vista
so is it safe to upgrade from vista ??
2:also i can't folder in player all the songs are listed one after another
vish1988 is offline
Old 12-07-2007, 03:50 PM   #12 (permalink)
devilzdad's Avatar
Question Re: T-sonic 610 or 630
dude howz the data transfer rate??? can u plz temme approx time taken by it to transfer 500MB??
Old 12-07-2007, 08:47 PM   #13 (permalink)
who cares...
vish1988's Avatar
it is aprrox 900KB/sec
vish1988 is offline
Old 13-07-2007, 09:48 AM   #14 (permalink)
kool's Avatar
dont buy T-sonic........... its verr slow data transfer..... u can check review in latest CHIP magazine!!
►► ◄◄ :smile::smile:
kool is online now
Old 13-07-2007, 01:20 PM   #15 (permalink)
ashisharya's Avatar
i have bought t sonic 630 n its pretty gud be it in sound, drag n drop, battery life, excellent display
go it for sure
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
ashisharya is offline
Old 13-07-2007, 04:26 PM   #16 (permalink)
who cares...
vish1988's Avatar
go it for sure
1 Q about 630
i can't see folder All the songs are listed one by one
but i have seen folder in my friends 610
vish1988 is offline
Old 13-07-2007, 05:17 PM   #17 (permalink)
Originally Posted by vish1988
[LEFT]
1 Q about 630
But in my T.610, folders are not seen, only the files.
V.Prem Kumar
janitha is offline
Old 13-07-2007, 09:50 PM   #18 (permalink)
The Blessed one
I think thye folders will be seen only when you record some FM radio or do some recording with the microphone.
The two folders you will seen then are FM and VOICE.
fatguysmart is offline
Old 13-07-2007, 10:22 PM   #19 (permalink)
D i s t i n c t l y Ahead
saurabh kakkar's Avatar
i too had the same prob. i am having T-610 what u do is create a new folder
in the T-sonic like u do in pen drive and put some songs in it
from the next time onwards u can drag the folders containing songs
worked for me
also fatguysmart is correct
@vish1988 have u purchased 2 gb t-sonic 630 for Rs 2650/-
cos i had purchased 1 gb T-610 3 monts ago for 2300/-
saurabh kakkar is offline
Old 13-07-2007, 10:35 PM   #20 (permalink)
worked for me
It is only natural since prices of certain IT products come down so fast. In my case, about 2 months back I bought my 2GB T.610 for Rs.3500/-!
And yes recordings are in separate folders.
But copying folders containing mp3s from the PC don't work. Only the mp3s are shown in the player.
V.Prem Kumar
janitha is offline
Old 13-07-2007, 10:42 PM   #21 (permalink)
Still Shining!
Lucky_star's Avatar
I can see all the folders in my T610. How come you are not seeing it?
I have arranged them as folders, subfolders(upto level 4)
And I can see all the folders.
Nokia N86 8MP
Old 13-07-2007, 10:43 PM   #22 (permalink)
Dreamweaver
Gigacore's Avatar
even t610 has a good battery life. and when i buyed it was 3.2k the bundled earphones is superb both in audio and build quality. the latest model will wont ship a good build quality earphones. though the audio quality remains same.
Gigacore is offline
Old 14-07-2007, 08:22 AM   #23 (permalink)
Thank you. I will try again and post.
BTW, have you tried the voice recording? If so, how is the quality@ 'high' setting?
V.Prem Kumar
janitha is offline
Old 14-07-2007, 08:28 AM   #24 (permalink)
Still Shining!
Lucky_star's Avatar
Voice recording is good. But you have to keep it still. A slight disturbance in the air is also caught by it. If you set the Environment to quiet, then recording becomes a problem, because, while you hold it, your fingers rub against its body and that vibrations are also caught by it. Overall, the rec. quality is good. But I am not satisfied with the FM. Maybe its the problem with my set. The recption is poor and quite noisy.
Nokia N86 8MP
Old 14-07-2007, 08:36 AM   #25 (permalink)
In my case, the nearest FM station is 70Km away and so the question doesn't arise.
V.Prem Kumar
janitha is offline
Old 14-07-2007, 08:48 AM   #26 (permalink)
Still Shining!
Lucky_star's Avatar
Hehe,
Here its the building next to my appartment. Just some metres away.
Nokia N86 8MP
Old 14-07-2007, 09:03 AM   #27 (permalink)
Dreamweaver
Gigacore's Avatar
and yes the transfer speed of t610 is bit slower. i agree with it. and you can use it as a pendrive for occasionally, its not suited for frequent use. t610 was also the silver medal winner is recent review by digit
Gigacore is offline
Old 14-07-2007, 10:29 AM   #28 (permalink)
who cares...
vish1988's Avatar
yes you can see folder
in t-sonic 630 go to settings-> playlist editor
and enable playlist editor
vish1988 is offline
Old 14-07-2007, 02:46 PM   #29 (permalink)
[LEFT]
In the case of my T.Sonic 610, Under Settings, there is no play list editor and there are only the following options - "About, Rec Quality, Rec Environment, Contrast, Language, Power Saving, Screen Saving, EQ and User EQ, Repeat Mode, Sync Lyrics" . The rirmware version is 3,4.
V.Prem Kumar
janitha is offline
Old 27-08-2007, 10:21 PM   #30 (permalink)
Commander in Chief
QwertyManiac's Avatar
I got a 630, any idea if it supports playlists? I can't figure out how to create them with the inbuilt thing. I need my songs played trackwise Does it support m3u files or pls ?
Harsh J
www.harshj.com
QwertyManiac is offline
charger for T.sonic 610 GunshotSilence Mobiles and Tablets 3 29-03-2009 02:42 PM
Transcend T.Sonic 610! Chrono Cr@cker QnA (read only) 9 25-07-2008 01:41 PM
queries regarding transcend T.sonic 610 saurabh kakkar Mobiles and Tablets 2 06-04-2007 01:59 AM
trancsend T.sonic T610 suyash_123 QnA (read only) 1 08-01-2007 06:49 PM
- by Krow
