Old 10-07-2007, 03:23 PM   #1 (permalink)
Default Upgrades!!
What are the parts in the core system of a laptop that can be upgraded?
CPU?
GFX?
etc.
If you can't beat your computer at chess, try kickboxing.
vutonium is offline
Old 10-07-2007, 03:25 PM   #2 (permalink)
slugger's Avatar
Default Re: Upgrades!!
depend on ur lappy cos policy
but usually grafix card can be upgraded
slugger is offline
Old 10-07-2007, 03:30 PM   #3 (permalink)
Sorry i forgot to tell.I hav a compaq presario c505tu with 1gb ram and 945GM chipset. can i upgrade gfx?really?
wha abt processor?
vutonium is offline
Old 11-07-2007, 06:45 PM   #4 (permalink)
Hellooo!!!
Nebody there??
I hav a big question.
Can the processor in a laptop be upgraded?
coz i kno 945GM supports core2duo
vutonium is offline
Old 12-07-2007, 03:42 PM   #5 (permalink)
g_goyal2000's Avatar
Well, u can upgrade anything in a laptop except screen, touch pad (if u can find one with exact fit, then good for u).
If the mobo has integrated audio & video chipset, then u can't.
If it has expansion slots for audio & video card, then u can.
RAM u can upgrade.
Processor u can upgrade.
And since u'r laptop has 945GM chipset, I'm guessing it's less than a year old. If such is the case, then ask u'r company for upgrades.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 12-07-2007, 07:20 PM   #6 (permalink)
Apart from my own vendor, does anybody know other reliable places where i can send my laptop for upgrades who wont beat the **** outta my laptop?
vutonium is offline
Old 13-07-2007, 01:45 AM   #7 (permalink)
U don't have to send it to someone for upgradation. If it's still in warranty, contact your company
Else, read ahead.
According to your location, it says u live in Mumbai.
So u can goto Lamington Road, find a shop that sells laptop hardware, purchase the upgrades & u can either get the laptop upgraded right in front of you or get it done from a computer geek friend or do it u'rself if u know how to.
Do not, I say, do not send it or give it away to anyone u don't know. They might remove good, expensive hardware & replace them with old, faulty ones.
If u don't need the old parts, then u can either sell them or keep them for future use or emergencies.
Old 13-07-2007, 01:58 AM   #8 (permalink)
Wire muncher!
infra_red_dude's Avatar
wha abt processor?
don't expect much. u can only upgrade the ram and the harddisk and toss in a dvd rw if its not there by default. thats it... nothing more... nothing less!
infra_red_dude is offline
Old 13-07-2007, 04:32 AM   #9 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
any parts that are installed on ports can be changed and probably upgraded..
afaik only CPU, RAM, miniPCI, PCMCIA, optical drive can be changed. other then these there is only the mobo.
Rollercoaster is offline
Old 13-07-2007, 11:17 AM   #10 (permalink)
Wire muncher!
stike out the cpu too. most of the midrange models and almost all sold hee in india haf a soldered cpu. so its upgrading that is ruled out.
i was in search of a minipci wifi card but i cudn't get it anywhere.. i mean.. anywhere!! i finally settled for a pcmcia card... so, if u own a laptop then don't expect much....
Old 14-07-2007, 12:19 AM   #11 (permalink)
Angry Re: Upgrades!!
Wow, this is the first time I've ever heard that CPU's are soldered to mobo in laptops sold in India!!!!!!!
So, that means that if we asked the company (from which we bought the laptop) to upgrade our CPU (while still in warranty), they would have to change the entire hardware cos how would they open a solder without damaging the mobo or other peripherals?????
I think that's why processor & mobo companies provide locks for laptop processors.
Have a look:
http://www.irisvista.com/tech/laptop...e-apart-31.jpg
http://www.irisvista.com/tech/laptop...te-1200-27.jpg
Do u see that little red circle beside the processor?? That's the lock that holds the mobile processor in place.
Here's another view without processor.
http://www.notebookparts.com/images/...368-001_tn.jpg
Look at that small bolt-head like looking thing above processor socket. That's the lock.
Dude, u really need to get u'r facts straight.
Old 14-07-2007, 12:41 AM   #12 (permalink)
Wire muncher!
thanks for the links but i stand by what i've said for most laptops. i dunno abt the newer breed of laptops tho.
Old 14-07-2007, 02:51 PM   #13 (permalink)
If you have seen processors soldered to mobo, then that's an altogether different story. BTW, can u post a pic of soldered CPU?
Laptop upgrades. vutonium Software Q&A 2 24-04-2007 09:57 AM
suggest me upgrades.... mukul Hardware Q&A 11 19-07-2006 09:17 AM
BIOS upgrades. vutonium Hardware Q&A 8 15-04-2006 03:05 PM
PC Upgrades sudhirkumar001 QnA (read only) 4 01-10-2005 11:13 PM
- by Krow
