Old 10-07-2007, 05:36 AM   #1 (permalink)
On the net
arnab2kool's Avatar
Unhappy Why my right click keeps popping out?
Why my right click keeps popping out? Its a ******* problem I havent seen before. If I am using any program its right click keeps popping out. For example if I am using FireFox and I am writing something in a Text Area of a form its right click menu pops out, if I press Esc and make it go, it still keeps popping out. Any program I use. And even when not running any programs. Example on the desktop nothing opened still the right click menu appears or the right click menu of the taskbar appears. I have installed and formatted XP so many times, but no use. The Antivirus is working fine too, found no infections. The firewall working fine too and no threats. I am using Windows XP with SP2.
Please guys help me, I am puzzled completely. Help me please, what to do.
Thank you.
YOUTHS are not USELESS
YOUTHS are USED LESS
CORE 2 DUO USER
arnab2kool is offline
Old 10-07-2007, 09:21 AM   #2 (permalink)
slugger's Avatar
Default Re: Why my right click keeps popping out?
check if ur keyboard does not have sticky keys. it cud so happen dat d keyboard key keeps getting pressed accidently when u r using ur comp. the key on the right of d MS key is 4 activating the menu as done by right click
slugger is offline
Old 10-07-2007, 09:28 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
either there is some problem in mouse or keyborad......plz check using ur frnds keyboard n mouse.
ravi_9793 is offline
Old 10-07-2007, 12:40 PM   #4 (permalink)
ayush_chh's Avatar
may be thr is some problem with your right mouse button!!!!!
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 11-07-2007, 01:17 PM   #5 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
remove the key from keyboard ......... & fix it again ........ sometimes it gets stuck & v dont realise it ...........
happens 2 me many times ..........
... W H O T ...
ax3 is offline
Old 11-07-2007, 04:44 PM   #6 (permalink)
piyush gupta's Avatar
Why not try to remove mouse and reconnect
piyush gupta is offline
Right Click = Left Click emailaatif786 Hardware Q&A 6 26-03-2007 02:48 PM
Pay Per Click Ads jain_pranav QnA (read only) 12 30-12-2006 08:58 PM
right click for bye bye! Cool Buddy QnA (read only) 1 06-09-2006 03:47 AM
!!!WIN XP right click!!! chillnow Software Q&A 12 24-06-2005 11:59 PM
- by Krow
