Old 09-07-2007, 09:05 PM   #1 (permalink)
vikramkh's Avatar
Default which cabinet is good
i am buying a new pc with core 2 duo processor and an asus p5bv motherboard so for better cooling and better looking which cabinet should i go for coming inside 2000
vikramkh is offline
Old 09-07-2007, 09:08 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: which cabinet is good
Best option is look locally, what I can suggest is, try to go for an cabi which has most Sockects to fit more FAN's in as u never know when u generate heat and if u then u need to add some extra cooling..
and most important point, too me the best cabi is a large Cabi
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 09-07-2007, 09:18 PM   #3 (permalink)
Attitude matters
Ponmayilal's Avatar
A good cabinet and a good powersupply that goes with it will be a permanent asset. So I would advise that you go in for a Coolermaster or Antec cabinet with atleast a 400W powersupply from the same brands even though they may cost you more initially.
Ponmayilal is offline
Old 09-07-2007, 09:36 PM   #4 (permalink)
The Frozen Nova
casanova's Avatar
iBall workhorse. Its damn good and costs around 1800 bucks
www.nerdweed.blogspot.com
casanova is offline
Good cabinet within Rs.3000 abhijit_reddevil Hardware Q&A 8 24-06-2006 02:23 PM
Good Cabinet+PSU under 2K??? montylee Hardware Q&A 10 19-06-2006 11:31 AM
which cabinet/smps will be good for this config ? myhotdog PC Components / Configurations 8 18-04-2006 11:33 PM
Looking for a good cabinet parimal QnA (read only) 19 14-09-2004 08:09 PM
- by Krow
