Old 28-02-2005, 08:39 PM   #1 (permalink)
Default fed up with message "hello"
plz help me to get rid of the problem "Hello".
i mean, when i copy any thing at any program n try to paste then it past onnly "Hello" at any times. like--> In MSWORD if i copied a text n paste it in to another place it paste "Hello". how could i solve this problem? do u have any idia?
Hey I am cool..........
kamaal is offline
Old 28-02-2005, 08:50 PM   #2 (permalink)
why need title?
bharathbala2003's Avatar
wierd problem.. try reinstalling OFFICE..
bharathbala2003 is offline
Old 28-02-2005, 08:55 PM   #3 (permalink)
may be word likes u vry much, anyways try re-installing OFFICE.
Shwetanshu Srivastava
shwetanshu is offline
Old 28-02-2005, 09:06 PM   #4 (permalink)
NikhilVerma's Avatar
Maybe a virus!
I am prettu sure a virus!!
NikhilVerma is offline
Old 28-02-2005, 09:06 PM   #5 (permalink)
i did but still i am facing the problem. i think it is virus. but not sure. does it happen if computer enfected with virus. if y then what kind of wirus is this?
kamaal is offline
Old 28-02-2005, 09:09 PM   #6 (permalink)
enoonmai's Avatar
You have been infected with the WuKill worm, also known as Wullik.B@mm. The worm will mail a copy of itself to all the contacts in your email address book and would probably have infected your computer because you clicked on a file called MSHelp.exe that would've come as an attachment in your email. It copies itself to your computer as mstray.exe or mshelp.exe.
Follow the instructions here to remove the virus from your computer, and also make sure you run an updated antivirus at all times.
http://securityresponse.symantec.com...llik.b@mm.html
BTW, yes, it does copy "Hello" repeatedly to the system clipboard, which is why you're getting that message over and over again. Visit here for more details:
http://vic.zonelabs.com/tmpl/body/CA....jsp?VId=41376
Playing FEAR XP/LSW2
enoonmai is offline
Old 28-02-2005, 09:10 PM   #7 (permalink)
Another Brick in the Wall
drgrudge's Avatar
I guess, the last word, u would have copied would have been hello and still when u copy another word, it doesn't get refreshed and still paste's as "hello".
Try refreshing and do the copying manuelly as see if it helps.
[edit]
Gosh! i was right! It doesnt get refreshed! And still shows that hello which was copied to the clipboard earlier.
drgrudge is offline
Old 28-02-2005, 09:47 PM   #8 (permalink)
enoonmai's Avatar
What do you mean, it isn't refreshed? He's infected with the virus, what about you? If you type "A" and then copy it, and then run "clipbrd" from Start>Run to view the contents of the Clipboard, you will see A in the Clipbook Viewer. However, if you type "B" then you WILL see "B" reflected immediately in the Clipbook Viewer, without a doubt, unless you're infected with the same virus as him or your Clipbook service is down or corrupted. What the worm does is repeatedly copy it to the clipboard, thats why he's seeing it again and again.
enoonmai is offline
Old 28-02-2005, 11:15 PM   #9 (permalink)
drgrudge's Avatar
^ thats wht i meant..., the A dint change to B..., and that maybe beacuse of virus as u say.
drgrudge is offline
Old 28-02-2005, 11:39 PM   #10 (permalink)
enoonmai's Avatar
So, you're infected, too?
enoonmai is offline
Old 28-02-2005, 11:46 PM   #11 (permalink)
drgrudge's Avatar
nope, why should i be?
drgrudge is offline
Old 01-03-2005, 12:00 AM   #12 (permalink)
enoonmai's Avatar
What the..? Didn't you say it didn't work for you when you copied text and it wasn't being refreshed? Did I misunderstand something?
enoonmai is offline
Old 01-03-2005, 12:05 AM   #13 (permalink)
drgrudge's Avatar
Hmm, i was right in telling that the clipboard had virus and the new word not getting copied...
Man, leave it, i hope his problem is solved...
drgrudge is offline
Old 01-03-2005, 05:26 PM   #14 (permalink)
then why isnt it called as the hello virus
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 02-03-2005, 12:45 PM   #15 (permalink)
i have the same virus but is add "A" in all the text fields got it cured too
vijaythefool is offline
Old 02-03-2005, 01:56 PM   #16 (permalink)
Just Do It
Charley's Avatar
Its a virus dude, check out using the stinger software
Charley is offline
- by Krow
